Alternator output GL1000
- tlbranth
Anyone know the wattage output of the alternator on a '75 GL1000? I've installed a new headlight with an H4 bulb that's 60/55watts which is a bit higher than the original 40/50watt arrangement. I've put LED's everywhere else but don't want to upset the alternator.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- flyin900
Re: Alternator output GL1000
Specs are in the FSM I just don't have access to one right at the moment. It is in the first sections of the FSM under specifications.
Current Bikes:
- tlbranth
I have the shop manual and looked for quite a while but didn't find it
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
- Zinc Member
Hi, i have this:
300w / 5000rpm
Jean
300w / 5000rpm
Jean
3800 Vélosolex (2)
125 MBK Skyliner
Naked 80 1100 GL almost complete
80 GL 1100 project
2003 GL 1800
125 MBK Skyliner
80 GL 1100 project
2003 GL 1800
If that is the only thing you have done with a higher demand then you should not have any issues.
- RB
Best is to check battery charging at various rpms while riding..real time test..voltmeter attached to battery..at idle should read close to 12v's at 3,500 13.5 or so..if you get that you should be good...so many variables in older bikes..wires,connections, regulator/rectifier, connectors, etc..running test the only sure way to know
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- salukispeed
Last I looked said the alternator is rated at 360 watt. My 84 interstate has all original lighting and will keep up with a heated vest and heated glove liners if used on the highway most of the time. As already mentioned a quick check with a voltmeter at 3,000 rpm is a good idea. You will actually need 13.5 volts to actually be recharging the battery. I see 14 at 3,500 even if the fan is running. All with a good and fully charged battery to start.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- tlbranth
Yes I will keep an eye on voltage. If it's true that the alternator always puts out full current and the unused part is dumped to the heat sink, then maybe overloading it wouldn't hurt it eh? Thanks Jean. I think 300 watts is it. I'll add up all my wattages and see where I stand.
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
I have tried to do that a couple of times but the ignition circuit always seems to stump me due to the constant cycling. I know I got close once and on a stock bike working perfectly I came to the conclusion you could add dual 35 watt driving lights but not dual 55's. So upgrading the single existing should not be even a blip on the radar.
- 23 Replies
- 1555 Views
Last post by redglbx
- 22 Replies
- 550 Views
Last post by salukispeed
- 10 Replies
- 437 Views
Last post by 441Victor
- 15 Replies
- 570 Views
Last post by Toehead
- 4 Replies
- 641 Views
Last post by CYBORG
