cooling fan issue
dontwantapickle
cooling fan issue
Post by dontwantapickle »
:-D
Last edited by dontwantapickle on Sun Jan 14, 2018 2:47 am, edited 1 time in total.
RB
Re: cooling fan issue
Post by RB »
Nope, but but I'd say low voltage?? try direct jump from batter see if it spins like it should?? Corroded loose wiring? Blade hitting/touching something..making it hard to start up?? bad bearings in the fan??
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her :(((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Yea the fans themselves do not have a know issue. Pretty great reliability so I would concentrate on eliminating the electricity supply as RB stated.
gregforesi
Post by gregforesi »
I' guessing a high resistance connection somewhere in the circuit. Corrosion in a plug would cause it.
The most likely suspect would be the connection at the temperature switch.
Check the resistance across the temperature switch when it's closed (bike hot). Should be near zero ohms.
12 volts straight to the fan plug (on the GL1000 - Blue is positive, black neg). The fan should spin right up.
If all of that checks out, put a gremlin bell on the bike. If you already have a gremlin bell, clean it and move it closer to the ground.
Fix #2 would be to put a remote pull-start cord on the fan motor. You could run it up next to the temp gauge so if you notice the bike overheating, the cure is right there too.
2006 GL1800 (Brutus Maximus)
Oldboy
Post by Oldboy »
I'm for Greg's fix #2......
Cheers...
Just Wing-it
