Fuel pump compatibility
I would like to convert my 77 to an electric fuel pump. 2.5 to 4 psi pumps are plentiful. Would one in that pressure range work for a pair of idf 40 carbs.
1977 Gl 1000
1976 F1 750 SS
1973 Ironhead chopper
2007 Road King
1974 dohc 450 chopper project
1976 Gl 1000 parts bike
600rr parts bike
1976 F1 750 SS
2007 Road King
600rr parts bike
Re: Fuel pump compatibility
The IDF 40's like pressure in the 3 - 3.5PSI range.
The www can be so confusing. The best I can figure is that the gl1200 fuel pump pressure is 3 to 5 psi..
1977 Gl 1000
1976 F1 750 SS
2007 Road King
600rr parts bike
1976 F1 750 SS
2007 Road King
600rr parts bike
I have a pair of Weber 40's on deck for my '78. I did a lot of reading and have amassed a bunch of chatter about the process. So far, I've been too lazy and the bike is running too well to begin the process.
I converted to a 1200 electric pump six months ago for starting issues and in anticipation of the Weber installation. The 1200 pump is reported as being a good match for them.
I used the stock 1200 pump on a 77 engine with good results. It is best to use a relay connected to the coil power wire so the pump only runs when the coils are firing.
- jdvorchak
Any carb I've ever seen, be it truck, car or motorcycle, used a 2.5 to 3.5 PSI pump. So I'm guessing that anything between 2 and 5 psi would work fine.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
I've used the Facet/Purolator electric, aircraft grade fuel pump on two of mine and they run awesome. I can come up with the part number if you absolutely want it. And they're virtually dirt cheap.
H2G2=42
H2G2=42
and probably way more information than you wanted.
H2G2=42
H2G2=42
I have the same display but mine are taped to the inside of the door right next to the sheets of paper where I track the oil changes!
I'm gonna try that pump. I like the shape of it.
Thanks.
Thanks.
1977 Gl 1000
1976 F1 750 SS
2007 Road King
600rr parts bike
1976 F1 750 SS
2007 Road King
600rr parts bike
- 6 Replies
- 645 Views
Last post by jdvorchak
- 12 Replies
- 512 Views
Last post by Dr. Frankenstein
- 4 Replies
- 281 Views
Last post by olchris
- 10 Replies
- 404 Views
Last post by OO7EDDY
- 20 Replies
- 568 Views
Last post by 82aspy
