While restoring this UniGo trailer, I noticed that the wheel had a lot of play. Thinking that the bearings were shot, I discovered this:
Apparently the bearing was spinning within the rim. My question... can this rim be repaired to fit the bearing or is the rim trashed?
Is This Rim Trashed?
- BlueThunder
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- salukispeed
Re: Is This Rim Trashed?
A decent machinist could bore the wheel to correct run-out and hole integrity , then turn up a bushing that presses in that fits the wheel and bearing, Provided the wheel hub is still sound and no cracks
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- dontwantapickle
Last edited by dontwantapickle on Sun Jan 14, 2018 2:32 am, edited 1 time in total.
- BlueThunder
Turns out a new wheel is only $199CDN. So after doing the conversion..... its basically free!dontwantapickle wrote:If it's going to involve machine shops, bearing houses, etc... ...and it looks like it is,
I would check into finding a replacement and just being done with it.
sometimes it ends up being a lot easier (and cheaper) in the end.
And since it is the only wheel on a one wheel trailer , I would want the best I could get, for safety's sake.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- 11 Replies
- 370 Views
Last post by jdvorchak
