cylinder 1 not firing.
- pierce
- My Album: pierce
For the past week I had popping put my right exhaust, usually only at idle. Discovered if I pull the plug on cylinder 1 it stopped.
Got on the bike yesterday. And cylinder one was not firing.
I replaced the plug wire, and cap this morning. And it still is not firing. I swapped 1 and 2, and it fired. However now 2 did not.
I am running mp08 coils from a 1500. Can they fail only on one cylinder?
It sure seems like that is the case. Am I missing something? Should I replace the coil?
1976 GL1000
1978 Gl1000
1978 Gl1000
- RB
Re: cylinder 1 not firing.
Not generally but the wiring connection at the coil could be bad..??
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
pierce wrote:For the past week I had popping put my right exhaust, usually only at idle. Discovered if I pull the plug on cylinder 1 it stopped.
I am running mp08 coils from a 1500. Can they fail only on one cylinder? YES
It sure seems like that is the case. Am I missing something? Should I replace the coil? YES
Cliff (74yrs )
- pierce
- My Album: pierce
Thank you. New coils ordered.
Hopefully this resolves the problem.
1976 GL1000
1978 Gl1000
1978 Gl1000
Just curious... would this failure be found by testing the resistance from wire to wire, i.e. an open circuit?
Yes. That's how I ultimately discovered the identical ignition failure mode. 3 different occurences.Track T 2411 wrote:Just curious... would this failure be found by testing the resistance from wire to wire, i.e. an open circuit?
I removed both replaceable plug wires from the suspected dual output ignition coil, each time, and resistance tested directly into their respective output sockets.
Cliff (74yrs )
- warhead_71
Wait... why did you swap 1 and 2? 1 and 4 are on the same coil. 2 and 3 are on the other.
- tlbranth
1&2 share a coil. 3 & 4 share the other.warhead_71 wrote:Wait... why did you swap 1 and 2? 1 and 4 are on the same coil. 2 and 3 are on the other.
Problem sounds to me like a bad plug.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
tlbranth beat me to it but yeah, 1/2, 3/4. If you are looking at a Clymer manual it has it wrong. These are also different from most inline 4 engines.
- warhead_71
my bad. but yes, seems like it's pretty much isolated to the wires or plug or boot if you can swap the wires and the problem moves with it. Not the coil.
- pierce
- My Album: pierce
Thanks for all the replies! I replaced the coil wire and plugs, had no effect.
That's what led me to think coil.
Still waiting on the coil s
1976 GL1000
1978 Gl1000
1978 Gl1000
- pierce
- My Album: pierce
Problem solved. Thanks everyone.
I replaced the coils, and that solved the problem.
1976 GL1000
1978 Gl1000
1978 Gl1000
- My Album: kkjolly2501@verizon.net
there is a resistor at the end of the plug wire that may be bad. Its inside the boot that plugs on the spark plug.
I have done so much with so little for so long, I think I could do anything with nothing at all, in no time flat. My best friend Buddy (my service dog) loves to ride as much as I do.!!! I would hope everyone would use a product called (Ride On) sealant & Balancer, in their tires, because it has saved my life.
1986 GL1200 A (new now driving) 7/1/17
1975 CB 750
1982 CB 900 Custom
1984 GL1200 I restoring
1986 GL1200 A totaled (may be parts bike) as of 6/19/17
1975 CB 750
1982 CB 900 Custom
Perfect.pierce wrote:Problem solved. Thanks everyone.
Cliff (74yrs )
- 12 Replies
- 440 Views
Last post by NotSoLilCrippseys
- 13 Replies
- 708 Views
Last post by pierce
- 13 Replies
- 274 Views
Last post by gltriker
- 50 Replies
- 967 Views
Last post by quarefish
- 21 Replies
- 521 Views
