Cooling system issues 79 GL
I took off my radiator this morning because I am replacing it with a much better one and I also wanted to check the fan switch.
The PO had a length of wire spliced in to operate the fan manually???
I pulled the thermostat housing and hooked an ohm meter to it. I submerged it into a pan of water (don't tell the wife)
and brought the temps up. The ohm meter showed a open circuit until It got to about 190 then the switch closed.
It opened up again at about 160.
I am guessing that this is what it should be doing.
While I was at it I submerged the thermostat and it opened up at about 180 or 185.
I am guessing that the switch and the thermostat are good so on to my next issue, The temp gauge is not working at all so I guess I have to pull the sender and check/replace it. Someone please tell me I don't have to pull the carbs to get to it .
Also I would like to replace the o rings at both the thermostat housing and the water pump inlet.
Are these available anywhere?
As always Thanks a bunch for the advice
Re: Cooling system issues 79 GL
o rings are available from honda.
if it was me..I'd replace the thermostat with a new one while you have it apart.
Did you check your water pump for lateral movement in the impeller?
It wiggles but just a little.
As 5speed says, I'd replace the t-stat while you're there. There's a listing for a generic auto t-stat in the cross-over parts thread. I like partzilla.com for most OEM stuff, cheaper and faster than Mother Honda. Just my opinion...
I just checked the sending unit and at room temp it showed .23 amps resistance,
at 150 degrees - .11 amps ,
at 190 .06 amps resistance
I'm not sure what the specs are for the sending unit, but a common problem with the temperature gauge is the 7 volt regulator, which can go bad. It also regulates voltage to the fuel gauge. There are several threads about it...
is it the original one with the bakelite impeller? If so you might want to consider replacing it.leggman wrote:It wiggles but just a little.
I'm kind of anal about preventative maintenance. My bike sat for 11 years so I replaced the rad, thermostat, hoses, water pump and fan switch.
The other two gauges work so I doubt it is the 7 volt supply. Plus when I ground the sender wire with a test probe the gauge climbs to halfway
- scootsx2
Ampere is not a unit of resistance.leggman wrote:I just checked the sending unit and at room temp it showed .23 amps resistance,
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
I stand corrected I should have said OHMS. Please forgive a novice mistake.
I checked the impeller and it does have a little side to side play, I would guess no more than 1/8 inch. It IS the bakelite impeller so it probably needs replacing but new ones are a bit pricey
ya..unfortunately they are.leggman wrote:I checked the impeller and it does have a little side to side play, I would guess no more than 1/8 inch. It IS the bakelite impeller so it probably needs replacing but new ones are a bit pricey
hopefully someone with more experience will jump in here.
I did the math and a water pump was cheaper than over heating an aluminum engine..
While 1/8 inch or so of 'play' in the water pump probably isn't going to lead to catastrophic destruction of the engine in the near future, "an ounce of prevention..." blah, blah, blah, lol. I'm not sure where you're at on your bike, ie. riding it now and doing this repair, or getting it on the road for the first time, etc. but I'd at least plan on a water pump job. The seals of the pump are seals between coolant and engine oil, and wobble in the shaft WILL lead to contamination of either or both at some level, at some time. Four out of five of my Wings, all with 45-50k miles, have had the water pump replaced. All had been sitting for various times before I bought them. It may be coincidence, but three of them also had a manual switch installed for the fan, as well. Just something to think about...
I have several, both rebuilt, and good used. Might be interested in parting with one
Not sure if 1000s use the same design, but I've rebuilt a 1200 water pump, just to see what was involved. I found two sealed bearings in there, just like wheel bearings. If the shaft wiggles AT ALL, at least one of those is gone.
- 11 Replies
- 612 Views
Last post by pjlogue
- 10 Replies
- 450 Views
Last post by NotSoLilCrippseys
- 6 Replies
- 461 Views
Last post by ofb
- 21 Replies
- 985 Views
Last post by head
- 32 Replies
- 641 Views
Last post by 5speed
