I found another hose that will replace just the lower radiator hose. It has a small bend/elbow to it. Use it as is, no cutting. I just put one on an 1100 today. You will still need the new style clamps as the original stock clamps are too big.
Gates 22038.
I saw another one that you could get two bottom hoses from if you needed them or if the store only has that and not the one above. That one is Gates 21404
Lower radiator hose
Lower radiator hose
Re: Lower radiator hose
good to know.
- garagedog
- Tin Member
I replaced the hoses recently and the stock clamps didn't quite work. I purchased these T-Bolt clamps and they worked great. A heck of a lot better than regular hose clamps. These will not pinch or cut the hoses. The top hose clamp is a little tight but it will fit.
http://www.ebay.com/itm/1PC-1-25mm-Turb ... 2749.l2649
Robin, can we get those numbers posted in the shop talk parts reference section for future use. Will probably not be able to find them when I next need them.
Thanks for posting.
Thanks for posting.
Funny you mention this. Good idea, but I already grabbed Robin's suggested P/N and have it filed in my local GL1000 Tech Folder.
Thanks for the tip, BTW, Robin. The hose I am running I literally went behind the counter at NAPA with the old hose and found something that I could cut down and use. This sounds even better.
desertrefugee wrote:Funny you mention this. Good idea, but I already grabbed Robin's suggested P/N and have it filed in my local GL1000 Tech Folder.
That's what I did. I have a bit of an "in" at my local Oreilly's.
Easter wrote:Robin, can we get those numbers posted in the shop talk parts reference section for future use. Will probably not be able to find them when I next need them.
Thanks for posting.
done
- 7 Replies
- 517 Views
Last post by Sidecar Bob
- 6 Replies
- 899 Views
Last post by robin1731
- 4 Replies
- 149 Views
Last post by desertrefugee
