I fix one problem then another one appears. My clutch will not disengage now. Before tearing the bike apart a few years ago the clutch was working okay. After getting the bike running I can't get the clutch to dis-engage. I think I have the cable ajusted okay as I have about 1/4 inch of slack when pulling on handle. When I first got the bike running the clutch was stuck so I gently put my foot on rear wheel and pushed down on it and the clutch seemed to free itself up. I took the bike for a short ride and it was shifting okay - no clunking while shifting gears. Now after the bike sat for a few weeks I can't get the clutch to dis-engage at all. The handle seems a little hard to pull on when trying to get the clutch to dis-engage.
I didn't do anything to the motor when I had it out of the frame except to put on new belts and tensioners.
Any ideas as to what I should try.
GL1100 clutch trouble
- My Album: http://www.ngwclub.com/gallery3/index.php/
1983 GL1100
Re: GL1100 clutch trouble
Start with the simple things... First, did you try to adjust the cable? Did you lube the cable? IIRC, the '83 doesn't have an adjustment to the clutch itself, just the cable. If you have the factory service manual, you might want to check to be sure.
I did adjust the cable per manual. It worked once after putting bike back together. Could it be stuck/sticky clutch plates? from sitting too long
I used Shell Rotel oil in bike?
1983 GL1100
- RB
Yes could be..there was a thread about 'breaking" loose stuck plates a few weeks ago..
viewtopic.php?f=1&t=61114&p=676101&hili ... es#p676101
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Yup. Sure sounds like stuck plates. British bikes used to be (for whatever reason) especially prone to it. I didn't read the link, but a quick and dirty method for attempting to free them is to fire it up in neutral and unceremoniously dump it into 1st a few times. It's a little harsh, but often will break them loose.
A much better, safer way, that isn't as hard on the transmission, is to put the bike on the center stand. Then with the engine off out it in gear. Then tie the clutch lever back or have someone hold it in. Then rotate the rear tire. That should break it loose if the plates are stuck. It will turn hard even after they are free but if you can turn the wheel then they are working properly.desertrefugee wrote:Yup. Sure sounds like stuck plates. British bikes used to be (for whatever reason) especially prone to it. I didn't read the link, but a quick and dirty method for attempting to free them is to fire it up in neutral and unceremoniously dump it into 1st a few times. It's a little harsh, but often will break them loose.
- 32 Replies
- 483 Views
Last post by japcrap
- 23 Replies
- 536 Views
- 7 Replies
- 931 Views
Last post by Cadillac Kid
- 17 Replies
- 531 Views
Last post by Sagebrush
- 0 Replies
- 380 Views
Last post by markwin
