Bad coil?
Bad coil?
Hello all… I've got a problem with my bike… Until it warms up completely it does not run on all four cylinders… Number one cylinder is lazy… It seems to me until the coil warms up that it does not want to run on number one cylinder… I've switch the wires around and pulled the plugs to make sure it was number one cylinder when it's cold it has no spark but as soon as the temperature gage hits the first part of the solid white warm line it starts running on all four cylinders and as long as it's warmed up it stays that way… I can ride all day long stop when I want to however long I want to but as long as the bike is somewhat warm it will start right up and run on all four cylinders… Do I have a lazy coil what do you think… New plugs and I cut about a quarter inch of plug wire on number one cylinder off and reattached also switched out the plug cap .....so my thinking is that I have a lazy coil… Thanks for your help
Re: Bad coil?
Try swapping the plug to see if it follows the plug?
Re: Bad coil?
You didn't say for sure that it does follow the wire when switched, but, if it is the coil itself, it would affect both cylinders (1 and 2) at the same time (one coil for 1-2, other coil for 3-4).
- Oldboy
Re: Bad coil?
I took both plugs out ground out number one plug no spark… Ground out number number two plugand got spark… Took plug one and put it into wire number two grounded out and had spark… Took number one wire and used number to spark plug and there was no spark… So number one wire was dead … All for spark plugs or new…
Re: Bad coil?
But as I said once the motorcycle warms up it runs just fine idles fine runs fine revs fine and everything
Re: Bad coil?
Maybe it's just the plug wire?
Re: Bad coil?
replace the wire......and ride on
Re: Bad coil?
K...I'll try the plug wire... luckily I have a 79 parts bike and this one's a 78
Re: Bad coil?
Well.... used coil and plug wire off parts bike .... Put them on and still runs on 3 cylinders..changed spark plugs ... it ran on all four cylinders .. waited five minutes....ran on three cylinders... when it runs on 3 cylinders it has no spark... before the change and after...... I got nothing. Besides a hate for electrical..........
Re: Bad coil?
Is it possible it's only running on two cylinders? They will run on two. If so, it could be points or electronic ignition. As Trak mentioned one coil feeds the 1-2 cylinders, the other feeds 3-4 and so each set of points triggers the same. Too be sure we're referring to the right cylinders, numbers one and three cylinders are on the right side, numbers two an four are on the left.
If you have Dyna electronic ignition, it is fairly common for them to begin dropping two cylinders randomly before giving up the ghost.
Re: Bad coil?
Interestingly enough when I checked for spark it was dead on # 1 cylinder and the others had spark... just woke up... need coffee in a cup..... then going to the shop and tinker with it again
- salukispeed
Re: Bad coil?
Very true that a failed coil will kill two cylinders normally but I had one that Ohm meter tested good and yet had a intermittent dead cylinder. it turned out the coil was cracked by the mounting and would short at times and cause only one cylinder to drop. As if you grounded one plug wire to the head the other one runs fine. Swapping wires side to side may confirm this if the problem moves. or possibly even swapping the coils side to side.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
Re: Bad coil?
OK my mistake the other day it was only one cylinder that dropped but this morning after switching the coil And the wires and the spark plug last night ..... as I said it did run on all cylinders last night for about a minute and then I turned it off five minutes later he did not run on four cylinders so I do have the plug wires where they should be… This morning I went and checked spark on all four cylinders number one and number two cylinder do not have spark at all… So at this point what are my options for another electronic ignition… Do I need a new control box and the electronic ignition on the motor?… Here's a picture of the control box and the electronic ignition on the engine… Hopefully the picture show up
- IMG_1441.JPG (177.77 KiB) Viewed 189 times
- IMG_1442.JPG (209.73 KiB) Viewed 189 times
Re: Bad coil?
That is an old version of a Dyna. Contact Dyna. They will have you send it in. If it is bad they will usually sell you a new one for a discounted price.
- 18 Replies
- 552 Views
Last post by rooster4321
- 12 Replies
- 532 Views
Last post by 5speed
- 340 Views
Last post by Oldtech
- 46 Replies
- 2698 Views
Last post by laurentg
- 3 Replies
- 133 Views
Last post by Tuono
