Low Air Warning Light
- chewy999
As some of you will know, I fitted Hagon shocks to my bike, and removed the air hoses as they weren't needed.
I disconnected the wiring and tie wrapped it out of the way, but I still have the warning light illuminating when I go for a ride.
Can an electrical guru please advise what is the best way to stop it lighting up.
Obviously I can just take out the bulb, but I read somewhere that you can do something to the wire for the same effect. I just need clear instruction so that there is no problem to my already suspect electrical system.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
Re: Low Air Warning Light
IIRC, the switch makes a ground when the pressure is high enough. Check to see if it's 'hot' when the bike is running. If so, pulling the bulb is the best way to fix it without messing with the wiring too much.
- BlueThunder
That implies that if the switch connects to ground that the bulb will go out. If this is true, then simply grounding the wire will turn the bulb off. I suspect however, that the switch grounds when pressure is too low - just like the oil pressure switch. In which case, DON'T ground the wire as it will blow a fuse. Either way, removing the bulb is the safest and easiest.Track T 2411 wrote:IIRC, the switch makes a ground when the pressure is high enough.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- mcgovern61
On my '82 I grounded the switch. No problems in 3 years. When the bike first starts, the light comes on briefly then goes off and stays off.
Gerry
Current ride: 82' GL1100
1st ride: 81' Suzuki GN400
- chewy999
Is the switch your talking about, the part the wire in the photo connects to? If so I removed it as I won't put the original shocks back on. So thinking about grounding the wire and have a spare fuse ready.
Previous Rides,
Current bikes
Current bikes
- mcgovern61
I disconnected the switch (like shown in the picture) and added a bullet connector to a wire, connected it to that wire and ran the other end to the bolt that holds the switch in place.
Gerry
- chewy999
I take it that stopped the light coming on with no adverse effects!mcgovern61 wrote:I disconnected the switch (like shown in the picture) and added a bullet connector to a wire, connected it to that wire and ran the other end to the bolt that holds the switch in place.
Previous Rides,
Current bikes
Current bikes
- mcgovern61
- chewy999
Thanks for all your help guys.
Previous Rides,
Current bikes
Current bikes
- 3 Replies
- 299 Views
Last post by Shadowjack
- 12 Replies
- 373 Views
Last post by lastwachter
- 1 Replies
- 283 Views
Last post by wehrd1
- 27 Replies
- 838 Views
Last post by Sidecar Bob
