The "new" rod for Mr.H's new engine came today and I was reading the section in the GL1100 FSM about the rods & bearings when I noticed that the same illustration is on P. 8-12 where it talks about the connecting rod weight code and on P. 8-16 about the connecting rod I.D. code. Both the '80-83 PDF version and my paper '80-81 manual contain the same error.
I looked it up in the '79-'81 GL1100 Haynes and illustration #23.5 (P.42) says "Bearing selection should be made by referring to the code number (letter indicates weight code).
"Impossible Is Just a Level of Difficulty!..." If I'd wanted you to understand, I would have explained it better! (Johann Cruyff) I’d give my right arm to be ambidextrous!
