Starting issues
Starting issues
What's up guys, I got a question and I hope no one beats me up too hard about this, but I finally got my bike running the other day and even rode it for a few hours, probably did 60 miles and all was good. It always started up fine previously. Maybe 3 days after I go to start her up. Battery's dead. Ok, I jumped it. Started right up. Let it sit for a few mins and looked around my battery and noticed the 3 yellow wires were kinda melted, read previously this could have something to do with charging issues. So I cut and crimped them together. Which I think solved my crappy battery issue. She's reads 14+ v now when running. Use to read only 12+ v. I'm kinda happy. So I shut her down and see if I can get a clean start...nope, just a loud click from the solenoid. Also noticed all these wires. Hopefully I can post pics and you will see. So my questions is, could it just be the solenoid that is causing the no start up and are these wires suppose to be here? I read there's suppose to be 2 main posts (the battery and the starter post) but I have a blue one seems to be grounded, green and red, which was not even connected, an addition red with white stripe and yellow with red stripe...if anyone could chime in or refer a previously similar post, I'd really appreciate it. Thanks!
- IMG_0358.JPG (245.77 KiB) Viewed 259 times
1980 Honda Goldwing Gl1100
-I ride naked-
This Is My First Motorcycle
Portland, Oregon
-I ride naked-
Portland, Oregon
- RB
Re: Starting issues
Someone messed with your wiring ..get a wiring diagram and set it up correctly. then sort it out..hard to know what's what as it's set up now...
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
Re: Starting issues
Ok, I found a diagram and pretty sure it's set up right. Pics below. I've tried a few things I've read to troubleshoot. I did the headlamp test which is I believe I read could be start button, the head lamps complete shut off when pushing in. I did the battery test with multimeter when pushing start button I get roughly .20 v increase. Don't know what that means. Also I do hear a click from the solenoid when pushing the start. I really don't want to pull the starter off which is why I'm checking everything else first. Any other recommendations of what to check....also I just realized there similar topics below..this quick reply box..I have some more reading to do. This fourm is awesome.
- IMG_0360.JPG (199.45 KiB) Viewed 230 times
-I ride naked-
Portland, Oregon
-I ride naked-
Portland, Oregon
Re: Starting issues
Check your ground wire behind the triangular motor hanger? It hides behind there pretty good. Take it off and look at the aluminum behind it. (On the motor) Sometimes they get pretty corroded from oxidation.
To check your starter, use jumper cables from the positive on the battery, straight to the lug on the starter. If that cranks it, you're starter's not the problem.
- salukispeed
Re: Starting issues
Also try using a old screw driver and cross the big terminals on the solenoid. if it cranks then the solenoid is suspect. All this after checking the connections on the battery cables and grounds as suggested. You might use a simple old 12v test light to see if you have power at the solenoid terminals and to the starter cable when you hear/feel it click.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
Re: Starting issues
Make sure the bike engine is in its neutral gear before making any engine start attempt via by-passing safety interlock systems.
Cliff (74yrs )
Re: Starting issues
Thanks for the replies, I read about jumping the positive to the stud of the solenoid, when I did that I got a spark, I wanna say that isn't normal. Am I suppose to remove the batt lead from the solenoid and jump to the starter stud? Sorry I'm learning new things. I checked the battery and noticed a few cells completely drained of water as well, gonna fill those up. Let me add that when I jump the battery to a car battery(car not running) she starts right up with no fuss. Then disconnect jumper and let her sit, then shut her down after 5-10 minutes. I try to start it up again the solenoid clicks super fast. Is that a sign of anything? Well I'll check ground and get some distilled water and add that to battery tomorrow. Thanks people and I'll keep ya posted.
-I ride naked-
Portland, Oregon
-I ride naked-
Portland, Oregon
Re: Starting issues
A battery with empty cells is shot.
Filling it with water and charging is pointless.
Get a new battery and service it correctly and completely, before installing it on the bike, and go from there.
Cliff (74yrs )
Re: Starting issues
gltriker wrote:A battery with empty cells is shot.
Awww man....the truth always hurts haha
-I ride naked-
Portland, Oregon
-I ride naked-
Portland, Oregon
- BikeMaine
Re: Starting issues
I just went through this myself. I received great advice as I always do on this site. I'll put a link on here.
I agree you need a new battery and a solenoid.
Just BE SURE when you order your new solenoid you pay attention to whether it's green or black. They're color -coded. Black like yours has positive post on left, green on right. EITHER ONE WILL WORK AS long as you pay attention to which one is the positive post.
Kevin
1982 GL1100A
1982 GL1100A
- BikeMaine
Re: Starting issues
Here's the link to my solenoid thread.
viewtopic.php?p=695133#p695133
BTW- when you "jump-start" a solenoid with the screw driver, it's going to spark every time. That's normal, just jam it on there and see if it cranks over. When it works correctly, it will spark, it will crank over most likely and it will melt some spots on your screw driver. All normal when crossing those posts.
Kevin
1982 GL1100A
1982 GL1100A
Re: Starting issues
You need a new battery. It's good you got the other wiring issues figured out. Since your cells were dry, I would lean towards checking the charging system thoroughly.
You need a digital multimeter to read volts to start. Many older bikes have charging issues which are often remedied by cleaning up wiring connections. Other times it's regulator or worse. Some pretty good diagnostics in Shoptalk.
Re: Starting issues
Good info!BikeMaine wrote:Here's the link to my solenoid thread.
-I ride naked-
Portland, Oregon
-I ride naked-
Portland, Oregon
Re: Starting issues
Yes thank you! I'm gonna purchase a new battery today at Walmart(ballin on a budget). I plan on getting a battery maintainer(I think that's what they are called) here in the near future. About the charging, I wanna say I fixed that. The three yellow wires were melted into the plug. I cut and crimped them with butt connectors for the time being. Before I did that I always had weak and dim flickering light. But when I jumped the battery all the light were beautifully bright. The multi meter was also testing high numbers when rolling on throttle. But we will see when I get that new battery and solenoid.ericheath wrote:You need a new battery. It's good you got the other wiring issues figured out. Since your cells were dry, I would lean towards checking the charging system thoroughly.
-I ride naked-
Portland, Oregon
-I ride naked-
Portland, Oregon
- RIP: cookie
Re: Starting issues
How high ? Too high ? 14.8 is about right at 3000 ....
If it's too high it will boil the battery dry .... check your regulator ....
Gord (careful I'm only a supervisor) Jones
- 22 Replies
- 684 Views
Last post by RacerEleven
- 4 Replies
- 320 Views
Last post by Bloodhound
- 30 Replies
- 778 Views
Last post by tallnwise
- 19 Replies
- 523 Views
Last post by Mrirbic71
