What are these?
- BikeMaine
What are these?
Please, what are these things and do they need to be bolted to a tab so they are grounded?
Kevin
1982 GL1100A
1982 GL1100A
- Sagebrush
Re: What are these?
They are the igniters in an 1100 ignition system. They are usually bolted back to back to a bracket under the left side of the shelter. The bolt holes are not for a ground, I always assumed the bolt other than a mounting point acted as a heat sink.
- chewy999
Re: What are these?
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- BikeMaine
- Steve81GL1100
Re: What are these?
How do the back sides look? They are notorious for having all the black epoxy sealant melt from the heat and ooze away... Mine had partially exposed innards and a lot of goo on the frame and components below where they mount. They seemed to work fine (still do), so I re-filled with rtv (yes, the dreaded rtv! ) and they've been fine for 3 years so far...
Steve
1996 BMW R1100R
1996 BMW R1100R
- Sagebrush
Re: What are these?
Only the igniters from the 80-81 bikes noted by black wire covers leak. In 82 they switched the compound and changed the vinyl wire cover to red.
- chewy999
Re: What are these?
Mine made a mess when the goo melted, so cleaned them up and filled the space with Araldite. Still work Ok!
Previous Rides,
Current bikes
Current bikes
- hatchward
Re: What are these?
this is where they mount
- 20170421_071251.jpg (142.3 KiB) Viewed 91 times
1982 GL1100 Std - Daily Driver
1982 GS750SZ Katana - Mostly Unmolested
1998 Valkyrie - Latest Aquisition
1984 GL1200 Aspencade - Undecided Project
- BikeMaine
Re: What are these?
The back sides look fine.Steve81GL1100 wrote:How do the back sides look? They are notorious for having all the black epoxy sealant melt from the heat and ooze away... Mine had partially exposed innards and a lot of goo on the frame and components below where they mount. They seemed to work fine (still do), so I re-filled with rtv (yes, the dreaded rtv! ) and they've been fine for 3 years so far...
Kevin
1982 GL1100A
1982 GL1100A
