Stripped bleed valve
Went to install my new master cylinder on the bike... pretty exciting considering the breaks are the only thing that needs to be done before the bike is road worthy!
But found that the bleed valve was leaķing... and tightening it up stripped the treads from the caliper
Looks like this is the second time this has happened as I've found these aren't the stock size bleed screws.
Anyways... I'm looking to use something like this picture. Has anyone used one before? Ive found a few on amazon but the quality is questionable and some of the products dont even specify the treads size :/ ...The bike is a '79
- flyin900
Re: Stripped bleed valve
Where abouts in Canada are you? If you have a thread size on the bleeder screw I have a complete master metric Time Sert set that may have the correct size of Sert to repair your caliper.
That brass insert should work as long as you have enough material to drill out of the caliper area and retap for the size of the insert. Doesn't really matter on the bleeder size thread if you are buying the whole kit as shown in your picture. You only need to drill and tap for the insert and the bleeder will thread into the brass insert correctly as shown in your picture.
Current Bikes:
I'm in Calgary. What is the largest size in the kit?
I was thinking that I'd have to go big with this repair since it seems it's already been upsized once. I'm not certain what it was tapped to just that it's not metric (Don't have SAE tread gauges).
One of the kits i found had a 1/8 NPT tread. I've sized it up with a 1/8 NPT tap and looks like it will have enough material... just need to find one that is a quality piece. This is probably the last shot at saving this caliper; i don't want to just chance it on something that is a "universal fit".
be carful .
the bottom of the bleeder is tapered, and seals with same tapered in the caliper. Installing the bleeder in an adapter piece, will not create a seal
Yes, I'm hoping that the adapter piece would have a new seat for the new bleed valve... I guess that's why I'm asking if anyone any experience with them... if there is a brand/supplier that they could recommend.
- flyin900
If it has been changed to a SAE style and already re tapped I wouldn't do any further work myself in trying to change it back to metric for you. I have a Kent Moore GM Northstar engine Time Sert kit that will do sizes from 6mm to 14mm sizes.
If you can use that kit you pictured it may be worth a try, or better yet a replacement caliper should also be considered. You may find a replacement one available from a member on the site here.
Current Bikes:
- 05c50
I've used the bleeder repair like the one shown in your picture. I bought it at a local NAPA auto parts store. The quality of the repair depends on your ability to drill and tap a hole in the caliper. The adapter uses a pipe thread on the outside thread and does have a machined seat to match the new bleeder. They come in different sizes, so try to get the smallest one so that you don't have to remove too much material from the caliper.
......Paul
......Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
Just ordered a some from online. Got a set of 4 with 1/8" NPT for 25 cad and free shipping.
My local part shops didn't have any. I just got a funny look before they told me I should buy a new caliper... I told them the make and model and they just as quickly said they didn't have any of those Haha
- jdvorchak
good thing you got a new bleeder and seat. The reason you old one stripped is the bleeder or the seat was no good. What a lot of folks don't know is that you shouldn't have to Godzilla tighten those bleeders if the seats are good. Just snug should be good enough. Otherwise replace the bleeder and hope the seat is still intact.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- delling3
I have spare a spare caliper from a '78 that I can send you if needed.
delling3
1979 Yamaha XS750SF
Previous:
2006 Kawasaki Concours: Sold
1979 Yamaha XS750SF
Previous:
Thanks for the help guys.
I've got the calipers tapped. I decided to do both since it looked like righty was treated to the same poor tap job as lefty. It's now looking pretty good; plenty of nice, new threads. Just got to wait for the parts to show up.
I'm considering ways to "permanent" the new seat in place for ease of bleeding and peace of mind.
Options that I see are
1 red thread lock at top most threads with teflon tape at bottom
2 Teflon full length of thread and stake the top thread
3 solder (No teflon needed)
Right now I'm leaning toward soldering it since it would serve to seal & hold in place, and could be undone with heat. Any thoughts?
- 05c50
I'm not aware of any solder that will work with aluminum (caliper) and brass (seat fitting). I guess you could use thread lock, but once the seat is threaded into the caliper, the bleeder shouldn't be tightened enough to cause the fitting to turn.
......Paul
......Paul
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
75 Goldwing
78 Goldwing
77 CB750a
77 CB550f
80 CB650c
05 Boule C50
- flyin900
The red thread locker is all you will need if you want to use something to hold the brass adaptor in place. It will seal and hold the part and can be removed with heat if necessary in the future.
Current Bikes:
Why do feel the need to do any of that? The seal isn't around the threads. It is where the screw "seats" at the bottom of the hole. Sealing the threads doesn't do any more.
Got the new seats.
The new bleed valve is tiny which made me a bit nervous. 1/4" head on it.
In the end I was more concerned with getting a proper seal over making sure it doesn't back out of the caliper. So I ended up putting them in with just Teflon.
Got a good bleed on them now so I'd call it a success.
Here they are with the one I pulled out of the caliper and another I pulled out of a caliper from a 70s CB.The new bleed valve is tiny which made me a bit nervous. 1/4" head on it.
- 0 Replies
- 321 Views
Last post by mikenixon
- 24 Replies
- 776 Views
Last post by rcmatt007
- 18 Replies
- 643 Views
Last post by Sidecar Bob
- 12 Replies
- 504 Views
- 8 Replies
- 297 Views
