Plumbing dribble
Plumbing dribble
so i replaced the plumbing seals but i get a SLOW and not much leak from the circled area (which has a gasket in there.
what im asking is i dont want to drain the fluid all again and remove it to see if thats it. is there something i can rub around the area to clog up the tiny tiny leak?
1980 GL1100I (parts)
1978 GL1000
"I Have No Idea What I Am Doing."
1978 GL1000
Re: Plumming dribble
you cna see the blue in this photo, it doesnt get much bigger then that every day.
1978 GL1000
1978 GL1000
- RB
Yes, and nope...
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- salukispeed
Likely The leak is coming from the inside so most things you put on the outside are temporary at best and the leak will return . Best is to verify and be 100% sure of the point of leakage and fix it correctly. And to try over tightening of the bolts is also a bad idea. Sorry!
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- Steve81GL1100
Check to confirm it's not leaking out of the end of the upper radiator hose. Those clamps have to be super tight -- tighter than I thought they needed to be -- or you will get a dribble. Also, if I remember correctly I smeared a little vaseline on the o-ring seal when I put it together, to prevent it sticking.
Steve
Steve
Steve
1996 BMW R1100R
1996 BMW R1100R
- 77Gowing
If you are going to use a lubricant on rubber you should use rubber grease because general purpose grease breaks down rubber.
On the chemistry periodic table elements are named in latin typically. Lead is called Plumbum, hence plumbing used to use lead pipe. So what you have is a Plumbing leak or dribble. Good luck with your problem, I sincerely hope it works out.
"Less is More" Anonymous
77Gowing
2014 Yamaha 950 V Star (sold)
77Gowing
I'll try the clamps. Then report back!Steve81GL1100 wrote:Check to confirm it's not leaking out of the end of the upper radiator hose. Those clamps have to be super tight -- tighter than I thought they needed to be -- or you will get a dribble. Also, if I remember correctly I smeared a little vaseline on the o-ring seal when I put it together, to prevent it sticking.
Steve
1978 GL1000
1978 GL1000
I found the culprit. After draining and semi removing the plumbing. The new oring I bought from Honda may be the issue? The old oring was corroded and gummed up. Is there anything I can put in with that oring to help seal better. To my eyes the surface looks clean. It did seem a little loose on the sleeve it sits on. I'm not sure :/ 2 steps forward one back. Bummed out.
1978 GL1000
1978 GL1000
Reseated the oring and put in the coolant. Still a leak. Bummer
1978 GL1000
1978 GL1000
- propav8r
A little RTV on the o-ring prior to assembly might not hurt.deathbypizza wrote:Reseated the oring and put in the coolant. Still a leak. Bummer
- flyin900
Are you sure that it is leaking from that O ring. I was chasing a leak that left a puddle in the same spot and it was coming from the small temp sensor O ring that is on the right hand side of the thermostat housing. You look to have some different style of sensor in there from the back side picture I can see.
It took me awhile to figure it out after removing the housing like you have done and using some Permatex gasket sealer specific for anti freeze on that O ring. When it still leaked I had the bike mostly still assembled, so it was hard to see the temp sensor properly, yet with a mirror I was able to determine the leak was from the temp sensor and not the thermostat housing.
If it is leaking just under the static pressure of the cooling system, once you fire it up and get pressure built there will be more than a little puddle. You do need to find and fix the issue correctly; not with a band aid solution as you have proposed.
Current Bikes:
- Toehead
May I ask why?CYBORG wrote:rtv?.....never
There are very few places that I would ever use RTV on a motorcycle, but this is certainly one of them. I'm not talking about a lot, just a barely visible coating on both sides to seal any surface imperfections.
I've had to use some RTV on similar things before and have never had issues.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
- tlbranth
Agreed.CYBORG wrote:rtv?.....never
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
I have a large tube of adhesive RTV that stated on the tube "do not use on engines". I have taken engine parts, including cooling system parts, that were sealed with RTV and leaked. And the sealant peeled of in one piece like a string of silly putty. Its sealing properties are compromised by both oil and ani-freeze.
- 33 Replies
- 1305 Views
Last post by Mike-C
