Plumbing dribble
- Toehead
Re: Plumming dribble
Yes, but RTV is also used by OEMs to seal thermostat housings and water pump housings. They make RTV for coolant applications, such as this.
https://www.amazon.com/Permatex-22071-T ... B0007TQW60
If you use the right grade, it works fine.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
agreed. That particular one is designed for water applications'. I agree there are specific blends that work in specific applications. But there are gasket dressings that work in a number of different applications,....which I preferToehead wrote:Yes, but RTV is also used by OEMs to seal thermostat housings and water pump housings. They make RTV for coolant applications, such as this.
- tlbranth
Hey Death, pleeeeeeease fix the spelling of 'plumbing'. I'm used to forum subscribers not being able to construct a sentence or spell anything over 3 letters long, but the title is right out there and makes me run for more whiskey.
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Right stuff, let me repeat that, Right stuff. As with ANY gasket sealer the surface must be clean and free of all contaminants. In my Auto repair shop we use Right stuff on many of the repairs we do. I use it on water pump, thermostats , oil pans etc. as a dressing to insure that they will seal. I don't have time to go back and redo a 4-5 hour repair because of improper sealing.
If I had installed that o-ring I would of put a small film of right stuff on it before installing it.
I used pure black gasket maker along with the o rings on all parts of the plumbing. I'll be reinstalling tonight and putting fluid in to see if it still dribbles. Thanks for all the help.
The sensor is for my acewell unit.
1980 GL1100I (parts)
1978 GL1000
"I Have No Idea What I Am Doing."
1978 GL1000
Re: Plumbing dribble
Well I thought I had fixed the issue. I put in the orings and also used black gasket maker to fill in any spots I thought it may be looking from. Well it's still leaking. This is the 3rd time I've taken it apart.
1978 GL1000
1978 GL1000
- tlbranth
+1 on the radiator hose note and also on lubing o-rings. I use some stuff called Sil-Glide. Bought it in the 60's so I reckon it's a lifetime supply. I sort of almost understand 77's concern about petroleum products on rubber (subsequent post) except I'm pretty sure all the o-rings on the bike are Buna and many are subjected to fuel & hot oil. So I reckon a little vaseline won't hurt. But what do I know.Steve81GL1100 wrote:Check to confirm it's not leaking out of the end of the upper radiator hose. Those clamps have to be super tight -- tighter than I thought they needed to be -- or you will get a dribble. Also, if I remember correctly I smeared a little vaseline on the o-ring seal when I put it together, to prevent it sticking.
Steve
Terry
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Don't own a Vanagon
Life is good
1999 GL1500 SE
1970 CB750
Well i added a second oring in the part that goes into the block. I think I found where it's coming from. As someone suspected earlier it's the acewell thermo sensor. It has a washer with a rubber oring in it. But I feel I should have used that now as the old unit was metal to metal. Should I just do away with that garbage washer.
Anywho here's the video. I thought it was the body of the thermostat first. So maybe it's this sensor washer. Here's a YouTube I uploaded.
1978 GL1000
1978 GL1000
Looks like a hole (whole so Tilbranth goes for more whiskey ) in the water housing.
- flyin900
The original sensor part had an O ring and as I noted earlier that can be your source of the leak and it is hard to determine if it is just a small seep. A lot of work sometimes to find these pesky issues so I am glad you found it.
Current Bikes:
- scootsx2
I use a film of dielectric silicone grease when fitting o-rings and similar rubber parts. It will hold the o-rings in place during assembly (make sure the mating surfaces are clean first), helps things slide together and doesn't attack the rubber.propav8r wrote:A little RTV on the o-ring prior to assembly might not hurt.deathbypizza wrote:Reseated the oring and put in the coolant. Still a leak. Bummer
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
Is it possible that you have straight cut thread on the sensor screwed into a tapered pipe thread?
- 33 Replies
- 1306 Views
Last post by Mike-C
