No light on 1 set of points
Hi I've recently been bringing back to life a 75 gl1000. When I hook up the test light and turn motor by hand the bottom set of points lights but when doing the top set I get no light.Any suggestions on where to look before I pull my hair out .thanx in advance.Hutch
Yeah its been a long strange trip AND thank you Jerry 1981 gl1000 and new to me 1975 gl1000
- ritalz
Re: No light on 1 set of points
Do the points physically open and close?
Yes AL they do open and close I only get the test light lit on the poit's on the left side .checked the wires coming from unit and all are good. I'm wondering if I shook a wire loose at the coils.thanx hutch
Well all connections are fine and tight. No spark on 3 and 4 plugs ,good spark on 1 and 2. Still no light up on the right side points which are opening when turning over .bad coIL ?
Pic of bike.
I had to change to a jockey style shifter since I had a stroke no can shift with left foot
- 20170315_152611.jpg (86.18 KiB) Viewed 126 times
- ritalz
My next step would be to look for voltage at the points and start tracing back. Could still be a loose or broken wire.
Thanx AL I found that the points in question were not making a good ground. This site has helped me out with alot of questions that sombody already asked. Thanx again AL she's purring again after 10 yr project
- ritalz
Good news
Great to hear! Cool jockey shifter!
Thanks wing rider everybody says no riding but with all the parts I had laying around I went the opposite of stock. Good therapy also
Am I correct for presuming You have good enough function in your left hand and arm to easily operate the shifter handle/clutch lever?domwing wrote:Thanks wing rider everybody says no riding but with all the parts I had laying around I went the opposite of stock. Good therapy also
Cliff (74yrs )
- 3 Replies
- 305 Views
Last post by Shadowjack
- 12 Replies
- 390 Views
Last post by lastwachter
- 1 Replies
- 287 Views
Last post by wehrd1
- 262 Views
Last post by Sidecar Bob
