Just when I thought I'd sorted it. Latest News
- BikeMaine
- chewy999
Re: Just when I thought I'd sorted it. UPDATE
Well, what a waste of time all that was!
As I posted here, https://www.ngwclub.com/forum/viewtopic ... 15#p695015, had a few learning curves to take on board. Anyway, exhausts and radiator went on easy enough, getting good at that, fitted the battery, new oil and coolant, turned the key and guess what, that's right, absolutely nothing!
Noticed two loose cables from the switch assembly hanging loose, so thought that may be the problem, but learnt that they were the cables for the brake light, so had to think again. Did the old screwdriver crossing the solenoid trick, and there was life, so what could be the problem?
What I discovered, and not sure why this would make a difference, is that when the switch flew apart when fitting the cables, there is a 'tapered' spring on the starter button, and I had put it in the wrong way round. Only realised this by turning it around, reassembling the switch and giving it a go.
FOR FUTURE REFERENCE, THE NARROWER PART OF THE SPRING, FITS AGAINST THE REAR OF THE STARTER BUTTON
The bike started really well, considering the carbs had been disconnected and started to warm up. Next to try the gears and see what happened to the neutral light. Again you've guessed it stayed on, but for some bizarre reason, it went out when in 4th gear! I am convinced it's not electrical, but suspect there may be a problem inside the engine where the ball on the switch makes contact. That is something to look into at a later date, like never, as I want to see if adding some miles helps out.
Finally, when the bike had warmed up a bit, switch her off, went for a restart and it was the same, just wouldn't, so went for a drink to stop me ripping her to bits. After calming down, I was reading an article where someone had a similar problem, but said his problem turned out to be the solenoid. So next when I'm off, going to warm the bike up, and try the screwdriver across the terminals. The thinking behind that is if it starts that way, it is the solenoid at fault, if it doesn't, it's the starter, but a little reluctant to splash the cash on an item that I may not need.
Anyway, that is all for now, as always, thanks to all who try to help out.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- BikeMaine
If I'm understanding what you wrote, your starter wouldn't turn over once the engine was warmed up.
My guess, and only a guess is it's your starter motor.
It doesn't take much resistance in the starter to cause trouble. When the starter drags our resists to turn, it overheats the solenoid. Most everyone agrees that an original Honda starter when rebuilt, is still better than a new aftermarket starter.
Not sure what services you have available where you live, but if you can find a business that rebuilds or refurbishes starters, it's quite affordable. I took mine to a local place that rebuilds starters, alternators and generators. (He even rebuilt the original generator on my 1948 John Deere M, [6 bolt, positive ground])
Anyway, for $40 he rebuilt my starter and it works like new.
Kevin
1982 GL1100A
1982 GL1100A
- BikeMaine
I followed those instructions and it helped a lot and got me through last summer. When I took it to have it fixed a couple weeks ago, he said I had cleaned it well, but he chucked it in a lathe and polished the commutator and installed new brushes and resoldered all connections.vmeyer wrote:fyi.. there is a very thorough write up with pictures on the steve saunders site on how to go through and clean up the starter if it is acting up.
Kevin
1982 GL1100A
1982 GL1100A
- chewy999
Thanks for that, the starter I have is an after market one to start with, I took it apart to check it out but it didn't seem to bad, maybe I wasn't thorough enough. I'll see if there's any local business' for advice.
Previous Rides,
Current bikes
Current bikes
- Zinc Member
Re: Just when I thought I'd sorted it. Latest News
With the neutral switch, I've found that if you park it in gear it will unstick itself over a short time.
When the hot start issue happens, will jumper cables (from a car battery to the bike battery) start the bike? If so, might need to replace the battery. It's not that unusual for a battery to fail when hot, then recover when cooled off. If it doesn't start, use the jumper cables to isolate a bad solenoid, cables, etc. If connecting the cables directly from the car battery to the starter doesn't work, probably a bad starter. Hope this helps.
- chewy999
I found this article on rebuilding starter motors, http://www.mrcycles.com/page/startermotors, which says that you should be able to turn armature shaft easily by hand. It's probably hard for people to judge what is easy over a discussion like this, but I wouldn't say mine is easy to turn, so may be time to risk buying a new starter to at least compare. It may be that although mine will turn by hand, therefore will start when cold, as it heats up something inside expands causing it to fail. Can anyone confirm that their armature turns 'easily'?
Reference the neutral light, I fitted a brand new genuine switch with a new heat resistant cable, and started the bike. Went through the gears and the light stayed on apart from 4th! Because I tested the switch as explained here, https://www.ngwclub.com/forum/viewtopic ... 29#p693929, I'm convinced it is an internal problem where the shaft that makes contact with the working end of the switch. Does anyone know which item that is in the transmission? I will get out and put some miles on the bike as that may help, at least help me!
Previous Rides,
Current bikes
Current bikes
This on an 1100? Going by memory here as I haven't done an 1100 before. There is a pin that has to be lined up with the drum. That can go in two different ways. One is correct. One is wrong. When wrong I think the light comes on when bike is in 4th gear. I may be off on some of this but there is something like that on the 1100.
- chewy999
Good suggestion Robin, but that is on the 83 model, (I think), and is at the front of the engine. The earlier models, like my 1980, just has the switch that goes into the lower right hand side of the engine and just pushes into place. It does have a hole which I believe should point downwards.robin1731 wrote:This on an 1100? Going by memory here as I haven't done an 1100 before. There is a pin that has to be lined up with the drum. That can go in two different ways. One is correct. One is wrong. When wrong I think the light comes on when bike is in 4th gear. I may be off on some of this but there is something like that on the 1100.
Previous Rides,
Current bikes
Current bikes
- BikeMaine
Before my starter was rebuilt, I could barely turn it by hand. After being polished on the lathe, it spins easily in my opinion.
Kevin
1982 GL1100A
1982 GL1100A
- chewy999
That's good to know, have to look into thatBikeMaine wrote:Before my starter was rebuilt, I could barely turn it by hand. After being polished on the lathe, it spins easily in my opinion.
Previous Rides,
Current bikes
Current bikes
- chewy999
Today I checked the bike will still start when cold, it did. Went to see if it would start when hot, it didn't! Checked the solenoid and that was fine so ordered a new starter from David Silver with the idea of comparing the old with the new as to how easy they turn by hand. If the same then I can return it. Also dropped a couple of emails to see about getting the old one fixed, but as it's Easter weekend won't hear anything till Tuesday.
Previous Rides,
Current bikes
Current bikes
- BikeMaine
Well, you've narrowed your trouble down. That's good.
Kevin
1982 GL1100A
1982 GL1100A
- chewy999
I think I have, still to be convinced after past experiences. Had soooo many knock backs!BikeMaine wrote:Well, you've narrowed your trouble down. That's good.
Previous Rides,
Current bikes
Current bikes
- 10 Replies
- 6888 Views
Last post by Whiskerfish
- 6 Replies
- 261 Views
Last post by Thunderdome74
- 31 Replies
- 2521 Views
Last post by robin1731
