The plastic backing/connector retainer on my ignition switch broke. Instead of buying a new switch (with non-matching keys) I bought the repair kit. It is resisting my efforts to install it into the keylock. Has anyone had a similar problem? Did you solve it? Seems very straightforward. Don't want to break the new plastic.
TIA
Emgo Ignition Switch Repair
- delling3
delling3
1979 Yamaha XS750SF
Previous:
2006 Kawasaki Concours: Sold
1979 Yamaha XS750SF
Previous:
- BlueThunder
Re: Emgo Ignition Switch Repair
I tried once and couldn't do it either. Ended up breaking the tabs rendering it useless. Ended up getting a Honda switch. Roncar has an excellent write-up to re-key a lock. He can also replace missing keys as well.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- roncar
One possibility, that is not in the GL1000 or GL1100 manuals but in the 'Honda Common Service Manual', is to have the switch in the position between ON and OFF to remove and install the contact base. That is the ACC position for switches that have an ACC position.
- ContactBase.JPG (99.1 KiB) Viewed 495 times
- delling3
Excellent information Roncar. You were spot on with that - I put the switch into the ACC position, and was able to snap the contact base in without issue. Terribly frustrating when people sell stuff, but don't bother to tell you key bits of information like this that isn't easily found elsewhere. Thanks again!
delling3
1979 Yamaha XS750SF
Previous:
1979 Yamaha XS750SF
Previous:
It does make sense to have to use the key to connect/disconnect the plug. It makes it a bit more difficult to hot wire...
- jdvorchak
That is pretty much the same on all Honda ignition switches I've seen.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- 13 Replies
- 1408 Views
Last post by Mojogameplay
- 15 Replies
- 1441 Views
Last post by pidjones
- 9 Replies
- 1104 Views
Last post by leonardhcross
- 1 Replies
- 680 Views
Last post by Sidecar Bob
- 14 Replies
- 3918 Views
Last post by mikenixon
