My wheel bearing tools
kerryb
Post by kerryb »
After learning the split-bolt method of removing wheel bearings, I was pondering the best way to put the them back in straight. I didn't trust myself to hit three different spots on the bearing rim with the same force each time. These pictures describe my somewhat crude, but very effective bearing driver system.
Pic 1...The whole system in use. wheel is suspended at work height on an upturned stool.
ready to drive bearing
High-tech wheel machine.jpg (77.4 KiB) Viewed 422 times
pic 2.
A 1/2" shaft is centered in the bearings by aluminum spacers made on the lathe
aluminum centering spacer
Pic 3. Steel driver block is a little smaller od than the bearing. turned on the lathe from recycled material. Smaller end is for front wheel bearings.
bearing driver.
bearing driver.
U se a piece of black iron pipe as a slide hammer over the center steel shaft and the bearing is driven in straight. Working out exactly when to stop hammering is the tricky part!
Hope this helps someone else with their creative solution to the next need.
kerry
kerryb
Re: My wheel bearing tools
Post by kerryb »
I forgot the spacer on the underside to keep the shaft square to the rim!
It is a block of wood made with a holesaw and split in two to allow tapping it into the underside of the hub before the second bearing is installed.
underside centering plug - wood.
alignment plug.jpg (85.04 KiB) Viewed 421 times
RB
Post by RB »
Looks like a tool one could sell..maybe adding a thread section up where the rod goes through the hub and add a plate and a nut that can be thread up tight to the hub for the first bearing going in???
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her :(((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
BikeMaine
Post by BikeMaine »
Great photos, thanks again Kerry
Kevin
1982 GL1100A
heraldhamster
Post by heraldhamster »
I like the way you think, man. THANKS for sharing!
H2G2=42
