Multimeter question
- chewy999
Multimeter question
Hi there,
I have a (old) Gunsons multimeter, and would like to know if anyone knows how to attach it for use as a tacho. The instructions show a diagram with the meter connected to a car, one terminal to ground and another to the coil securing point, but not sure where to connect it on a GL1100 with two coils and no obvious point. (can't remember the colours of the meters cables, but can look that up)!
If anyone has a similar meter if not the exact one, sure the principle will be the same.
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
Re: Multimeter question
I have a "Engine Analyzer" that looks similar. I put the ground to the battery ground and the red to one of the bullet connectors where the points/dyna hook into the main harness on a 1000. Because of the wasted spark system mine reads half scale, so when running 1100 rpm I get 550 on my meter but it works. If you can find a way to touch any of the trigger wires from the timing module it should work, it just needs to see the pulses.
- chewy999
Thanks for that, but a little confused as the 1100 doesn't have points as I'm sure you know. Maybe someone else knows where to hook up the second wire?
Previous Rides,
Current bikes
Current bikes
I do not know 1100 wiring well enough to provide that info. Maybe where the coils plug into the harness??
- jdvorchak
Try hooking it to the wire, on the primary of one coil, where that wire goes to the ignition (trigger wire).
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- chewy999
Thanks for that, I'll give it a go and report back. Off for a few days so may be next week now.
Previous Rides,
Current bikes
Current bikes
- jdvorchak
And play with the "Range" and "Cylinder" switches. Try low range and 2 cylinders first. I never have figured out how to use one of those for accuracy on a 4 cylinder, two coil, wasted spark ignition. That much math hurts my head. You have to realize that the particular tool was used on a distributor ignition. That means for every two revolutions of the crank the distributor would make one full turn. So with an 8 cylinder engine the rpm readout would be two RPM, of the crank, for every 8 pulses it counted.
2021 HD Triglide
John
2021 HD Triglide
John
- BlueThunder
Set it on 8 cylinders and it will read correctly for our bikes.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
Mine does not.BlueThunder wrote:Set it on 8 cylinders and it will read correctly for our bikes.
- BlueThunder
The 8 cylinder setting will read double on a 4 cylinder motor - with a distributor. Since the meter will read 1/2 of what it should on our GoldWings, due to the double spark, the 8 setting should give a correct reading. Mine does, but it is from the '70s.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- 4 Replies
- 1459 Views
Last post by desertrefugee
- 4 Replies
- 890 Views
Last post by Sidecar Bob
- 22 Replies
- 1318 Views
Last post by hatchward
- 145 Views
Last post by John Schmidt
