Fitting an oil dipstick for a GL1000
TNTbefree
Re: Fitting an oil dipstick for a GL1000
Post by TNTbefree »
Now that that is settled and everyone has a dipstick, welcome to the club Swanpondwv.
Hope you stick around. It is a very good forum, and gang, here on NGW. As you can see, we try to look out for each other as best we can. When you get a chance, swing by the Welcome and Introductions section and start a New to NGW post and tell us a bit about yourself and how you came about needing a dipstick for a Goldwing.
SnoBrdr
Post by SnoBrdr »
JBz wrote:honestly I never received the PM from swamppond. It wouldn't have made any difference As I would have given Youngster first dibs anyway. I have this other one if interested SwampWV. It could use some wire brushing , paint and a new crush washer .<stock Honda item> $30.00 shipped. ... jb
Does that screw into the drain plug ?
78 GL1000 Original Owner 131k
Swanpondwv
Lead Member
Lead Member
Post by Swanpondwv »
Yes it does.
Bill
Swanpondwv
Lead Member
Lead Member
Dip stick received from JBz as promised.
Thank you JBz!
And thanks to this forum.
Bill
Youngster
Zinc Member
Zinc Member
#20
Post by Youngster »
I got it in the mail, thank you. You were saying that I would need a new crush washer? So I shouldn't recycle the one that you sent with the kit? Do the little rubber washers fit on either side of the compression fitting ferrule? Thanks again. Sorry for all the questions.
BlueThunder
#21
Post by BlueThunder »
I got mine from Wingovations. Fits nicely and a necessary item that Honda should have included.
...Brian
1977 GL1000 - Ox
SnoBrdr
#22
Post by SnoBrdr »
BlueThunder wrote:I got mine from Wingovations. Fits nicely and a necessary item that Honda should have included.
Was it on their www, I looked but didn't see it.
BlueThunder
#23
Yeah, I looked the other day and didn't see it. Possible that I got the last one. Contact Old Fogey to inquire if more are coming.
...Brian
1977 GL1000 - Ox
JBz
#24
Post by JBz »
Youngster wrote:I got it in the mail, thank you. You were saying that I would need a new crush washer? So I shouldn't recycle the one that you sent with the kit? Do the little rubber washers fit on either side of the compression fitting ferrule? Thanks again. Sorry for all the questions.
chuck the rubber gizmos. Those are the halves of a old weathered grommet that went into the top mount hole and the tube slides into that . Go to Ace or home depot and get a new one. I sent a new crush washer with it. Use that and chuck the old one.....jb
