Need some help with my new Dyna Ignition
- Brass Member
77 GL1000, 50k miles, had an issue where it would start up and idle great, but then not hold and idle and die when the bike was up to temp. Had an ancient dyna ignition system so I tossed it all. I hooked the new ignition system to the new green dyna coils I bought with no ballast resistor and spliced the power wire in to the turn signal relay. When it cranks it'll have nice spark on all cylinders. When I go to crank it it'll sputter and then die as soon as I release the starter button. Any ideas? Think it's a timing issue or something with how I hooked it up? Any guidance on setting the timing would be much appreciated as well.
Re: Need some help with my new Dyna Ignition
You ditched the ballast. Did you then connect the wires that ran to it? They need to be wired together to work.
- Brass Member
I don't believe so. Just connect them together?robin1731 wrote:You ditched the ballast. Did you then connect the wires that ran to it? They need to be wired together to work.
Yes, follow the wiring for the ballast. If I remember correctly you can just plug it in using the stock wiring. No splicing or connectors to add.
- Brass Member
Awesome thanks I'll give it a shot in the morning and report back.
- 0 Replies
- 427 Views
Last post by gltriker
- 10 Replies
- 561 Views
Last post by ericheath
- 9 Replies
- 508 Views
Last post by Hanslehoff
- 15 Replies
- 892 Views
Last post by oldmike
