Clean rusty headers (chrome) easy
- jdvorchak
My old GS850G is about ready for the road. It runs great but still the past dozen or so years of neglect by the PO left it looking a little funky. I recently used plain white vinegar to clean the fuel tank and being cheap, when I was done with the tank I poured the used vinegar into a 5 Gallon bucket. Well I was just staring at the old girl and the exhaust pipes looked bad. So I tried aluminum foil on the rust and pits and it worked ok. Then I saw on the interweb to dip the foil in tap water and worked pretty good actually. Still searching I saw plenty of videos about using Diet Coke instead of water. Well we don't drink Coke or Diet anything so rather than go out and buy a can, remember I'm cheap, I used my left over Vinegar instead of water or Coke. I figured if vinegar will eat rust and aluminum foil removes rust from chrome, why not combine them. Wow did that work good. Here are some before and after pics. This literally took less than a minute of scrubbing with the foil dipped in plain used vinegar:
Took about 3 more minutes to clean all 4.
Now do they look new. NO. Not by any stretch but they look a lot better and I'm thinking some chrome polish will make them look even better.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
- jdvorchak
Re: Clean rusty headers (chrome) easy
One tip. Wear gloves unless you just like having your hands dirty and smelling like vinegar.
2021 HD Triglide
John
2021 HD Triglide
John
Incredible really. And sounds like it is extremely quick too. I would have never known you
could do so well with those pipes. I would have been looking for a better used set
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- jdvorchak
I've used everything from a wire brush, steel wool and emery cloth. This is by far the easiest I've ever seen. I was absolutely amazed. On the rest of that left side exhaust was just dirty. Just rubbed over it with the vinegar and foil and it came out looking like new! Vinegar is a great cleaner.
2021 HD Triglide
John
2021 HD Triglide
John
- RIP: cookie
Good tip .....
- gadelsperger
I assume you rinsed the vinegar off afterwards.
George in Rancho Cordova (Sacramento is a suburb) CA
- jdvorchak
Just wiped it off with a paper towel but yes I should rinse it. I'm not done, that was just a quicky job to see how it would work. I also want to try using steel wool and chrome polish or foil and chrome polish. I have a kz550 that is no where near that bad but has some rust.gadelsperger wrote:I assume you rinsed the vinegar off afterwards.
2021 HD Triglide
John
2021 HD Triglide
John
- Lucien Harpress
I want to say I remember (in the scary recesses of my mind) that I used steel wool for something engine-cleaning related. BIG mistake. The small steel fibers that ALWAYS shed from the pad got everywhere and rusted faster than I would've ever believed.
This is not saying you shouldn't try it. Just though you should be aware of a (possible) side effect.
Lucien Harpress wrote:I want to say I remember (in the scary recesses of my mind) that I used steel wool for something engine-cleaning related. BIG mistake. The small steel fibers that ALWAYS shed from the pad got everywhere and rusted faster than I would've ever believed.
That's why you use the Stainless steel wool. Not the cheap kind.
But you should always blow it all off after using it too.
- Lucien Harpress
I may have tried washing it...... I'm sure that didn't help any.
(Like I said. Long time ago, when I knew less about these thing than I do now. And I still don't know that much...)
- salukispeed
Pretty awesome result. Will have to give it a try on the 66 Dream, and a couple spots onthe silverwing. Do any of the smarter chemist types here have a answer as to why it works this well?
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- HOTT
Plain Ol' Vinegar has a ph of about 2.5.
You can purchase commercial grade stuff that will take your fingerprints off.
So it's pretty much acid. If not neutralized it will corrode most metals and stain others.
Use carefully.
scratching to chrome plating you might want to consider Bronze wool. HOTT (hmm smells like salad)
Use carefully.
Not that I'm saying I haven't used steel wool on rusty pipes,.. but if you want to avoidThat's why you use the Stainless steel wool. Not the cheap kind.
- BlueThunder
+1. Copper or bronze wool. Steel wool, even 000 size, will scratch the surface.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- calif wingnut
For some reason I can't post new topics or reply to so using quote for now, but just tried your tip on one of my markland 1500 back rest rails...I'm impressed.Lucien Harpress wrote:I may have tried washing it...... I'm sure that didn't help any.
- IMG_8180.JPG (164.79 KiB) Viewed 233 times
- IMG_8181.JPG (156.71 KiB) Viewed 233 times
- Sugs
...and copper or bronze wool won't rust like steel wool.BlueThunder wrote:+1. Copper or bronze wool. Steel wool, even 000 size, will scratch the surface.
_______________________
'79 Honda GL1000 Goldwing
- 13 Replies
- 1159 Views
Last post by Gc33
- 4 Replies
- 512 Views
Last post by Rat
- 3 Replies
- 327 Views
Last post by jdvorchak
- 9 Replies
- 402 Views
Last post by Barney T Weasel
- 387 Views
Last post by 5speed
