Help! 2 dead cyl.
- fish
Re: Help! 2 dead cyl.
you can unscrew the bowl drains with out pulling the carbs.
obviously fuel should run out of all 4 carbs
Timothy Mark Fisher
Catalina Arizona
Catalina Arizona
It likely that i may have overlooked a part of this thread/post, but i still dont know if there is an actual spark at the 1/3 plugs when turning over with ign on... ..
Put new tyres on it, new battery and paint job, wont make the plug fire at the right time....
1975 Goldwing #1 SOLD
- Zinc Member
there is fuel in the bowlsfish wrote:you can unscrew the bowl drains with out pulling the carbs.
- Zinc Member
There is fire at both plugs and it seems to be a good strong spark. With the motor running and a screw driver in the plug wire cap the spark will jump at least 3/4" to 1" to ground. service manual shows a 1/4" minimum using a spark plug tester which I don't have. Shorting it to ground and getting a 3/4" spark should be good.olchris wrote:It likely that i may have overlooked a part of this thread/post, but i still dont know if there is an actual spark at the 1/3 plugs when turning over with ign on... ..
- Zinc Member
I am thinking that using the aftermarket jets and float valves and also the aftermarket fuel needle may be the problem. I have since learned from Howard Halasz that the aftermarket parts are suspect so since I still have the old parts I am going to clean them in my carb cleaner and put the OEM stuff back in. I also got a Float gauge coming from Randakk's to set the floats with so I know that I am setting them correctly.fish wrote:you can unscrew the bowl drains with out pulling the carbs.
- jdvorchak
it is not uncommon, even for those of us who have rebuilt many carbs, to not get it right the first, second even the 4th or 5th time. Those idle circuits are tiny and hard to clean. I would suggest that you have pretty much eliminated ignition timing and spark so that leaves fuel delivery.
Personally I would pull the carbs once more and make sure the carbs are clean. Soaking in carb cleaner doesn't always do it. You have new jets so I am leaning toward the internal carb body passages. While you have the carbs on the bench squirt carb/brake cleaner through both sets of jets. You should see the carb cleaner come out inside the carb throat somewhere and it should be a good stream.
Good luck.
Good luck.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
Throwing this out there. When you put the carbs back together did you by chance close the mix screws on 1 and 3 but the did not open them back up? I always seat them and then back them out to the factory setting. Maybe they are still seated.
- Zinc Member
no they were backed out 3 turns and since I got it running I have adjusted them on the bike made very little if any difference in the way it ran.........On this note........what kind of tool do you guys have to adjust the carbs....I have one of the motion pro 90 degree tools that they say will work on the Goldwing and it does work but not very well especially on #1 and #2 carbs. I want to get another one that is easier to use if there is something out there.robin1731 wrote:Throwing this out there. When you put the carbs back together did you by chance close the mix screws on 1 and 3 but the did not open them back up? I always seat them and then back them out to the factory setting. Maybe they are still seated.
- Zinc Member
I did this before I had the Jets back in the carb but not with the jets in......I followed the post in Shop Talk that Roady has posted. It has a diagram in there of where each passage goes. They all seemed clean and the stream came out where he showed it should..... that's not to say I didn't miss something though. I will do this again while the carbs are off and with the jets in place before I take them apart and again after I go through the carbs again.jdvorchak wrote:it is not uncommon, even for those of us who have rebuilt many carbs, to not get it right the first, second even the 4th or 5th time. Those idle circuits are tiny and hard to clean. I would suggest that you have pretty much eliminated ignition timing and spark so that leaves fuel delivery.
Good luck.
- RB
If you grind part of the collar off the tool it will fit on the carb tower better..take a look while the carbs are off..you'll see what part needs to ground off/down.
+1 on aftermarket jets not being right half the time, +1 on setting the floats again, take a look at eh plugs after running her..plugs wet on 1 and 3?? or dry, black or tan? tells you a lot.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- fish
there is lots of stuff in the way, that is a crowded area!trat wrote:It is wired the way you have it drawn....I just verified itfish wrote:You have the wire that is supposed to go on sparkplug #3 on #1
You have the wire that is supposed to go to #1 on #3
that makes it allmost impossable to visually verify the plug wires are going to the correct plugs.
It is sooooo eeeasy to just yank the #1 off and stick it on #3 ,
and crank it over
Timothy Mark Fisher
Catalina Arizona
Catalina Arizona
- Zinc Member
I did that......no changefish wrote:there is lots of stuff in the way, that is a crowded area!trat wrote:It is wired the way you have it drawn....I just verified itfish wrote:You have the wire that is supposed to go on sparkplug #3 on #1
and crank it over
I did that......no change[/quote]trat wrote:
No change??!! If they were right before and you swapped them you should have gotten some backfires.
trat wrote:snip..........
no they were backed out 3 turns and since I got it running I have adjusted them on the bike made very little if any difference in the way it ran..........
Did it run different? Try running them all the way in and does it run different? It should want to die, if not die, when all the way in. If not the idle circuit is plugged.
- Zinc Member
robin1731 wrote:I did that......no changetrat wrote:
No change??!! If they were right before and you swapped them you should have gotten some backfires.[/quote] Thats why I think there is a fuel delivery problem.....no fuel, no back fire....I know there is good spark and good compression and timing is correct.....
- 11 Replies
- 1116 Views
Last post by mrtwowheel
- 15 Replies
- 627 Views
Last post by digger
- 1 Replies
- 276 Views
Last post by pidjones
- 19 Replies
- 1015 Views
Last post by Sidecar Bob
- 23 Replies
- 691 Views
Last post by sphen
