Just wondered if anyone knew what starters are interchangeable on the gl1200s?
I have an 86 1200 in my 1000, but the 84 starters housing is quite a bit smaller, and the 86 (fuel injected if it makes any difference) is getting in the way
the 84 bolt pattern seems to be different than the 86
gl1200 starter compatability 84-87
1977 GL1000, with GL1100 engine and carbs....in progress
1984 GL1200 Ascenpade gone naked...............in progress
1976 GL1000 1200 Engine, 1200 wheels...........in progress
1983 GL1100 Stock, fully functional!
1982 GL1100 ..................................................in progress
1976 GL1000 Stock resto....................... .........in progress
1978 GL1000....Upgraded...Bad cylinder............in progress
1982 CB900, 83 GL1100 rear end, 2006 gsxr1000 front end, 1200 front wheel..... in progress
1981 CB750k Needs attention.... in progress
The more time I spend on here the farther behind I get
Re: gl1200 starter compatability 84-87
84 is a stand alone starter
So are 85-87's identical?
I believe so
- salukispeed
Cyborg is correct. The 84 is unique and the rest are interchangeable. 84's are harder to find.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
It's amazing what cleaning and new brushes will do if done in time.
I have 3 84 starters..., i wanted to use one on the 86 because they are much smaller
but the 86 starter housing is massive
My gl1000 engine/frame brace was rotted, so i took a gl1100 side brace, and welded the gl1000 rear tab on it.. but the housing on the 86 is so big its interfering for some reason, so much that the starter is actually sitting on the frame brace tabs
unless the gl1100 side brace is different other than the rear end tab?
but my dad had done this to a gl1000 and had no problems, even though im trying to mount a 1200 in it, but the engine mounts on all 3 engines were same....
The side braces are all slightly different. From Sunnbobb
- 6 Replies
- 240 Views
Last post by Mrvn
- 0 Replies
- 1307 Views
Last post by Sidecar Bob
- 190 Views
Last post by ritalz
- 8 Replies
- 296 Views
Last post by FADM Stern GNSF
