How to quiet mufflers?
- Offcenter
Hey guys,
I recently got my '76 on the road with a set of seemingly new Harley FLH mufflers on it.
Even though the mufflers appear new and unmolested, the bike has a heck of a bark.
My ears are still ringing. I like quiet bikes. There is no way I'm going to enjoy riding
this thing any distance....which is what I want to do!
I was thinking of getting some stainless steel wool and stuffing it into the inlet
end of the mufflers. Would this quiet them down without restricting the
giddy up 'n' go too much?
Any and all suggestions appreciated!
Thanks guys.
Thanks guys.
George in Jersey
76 GL-1000
77 Trail 90
It's called a "Dresser".
A bagger is an old lady who lives under
a bridge with her crap in a shopping cart.
76 GL-1000
77 Trail 90
- JBz
Re: How to quiet mufflers?
are they the Harley mufflers that come apart on the tail end with 3 allen bolts. If so they could be repacked............... if not just putting stainless steel wool probably wouldn't help much unless the washer is way down there. and I wouldnt recommend that way but might help jb
- BlueThunder
Don't use steel wool or home fiberglass packing. They don't last and eventually blow out the pipe. Use muffler packing material. You'll be happier in the long run.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
- Offcenter
I just looked. No allen bolts or screws of any sort.
These things are welded in one piece.
I'm hoping to get some first-hand advice on this.
I already have some hearing loss and don't need it to
get any worse.
Sure wish I could get the original mufflers for the thing,
but they are no long available....at least not at a price
that any normal human can afford!
get any worse.
George in Jersey
76 GL-1000
77 Trail 90
76 GL-1000
77 Trail 90
- Offcenter
Muffler packing material? First I've heard of it. Suggested source, Brian?BlueThunder wrote:Don't use steel wool or home fiberglass packing. They don't last and eventually blow out the pipe. Use muffler packing material. You'll be happier in the long run.
Thanks!
George in Jersey
76 GL-1000
77 Trail 90
76 GL-1000
77 Trail 90
- salukispeed
I think I saw some after market baffles that you might adapt to the inside of the Harley mufflers you have. I may have seen them in the JCWhitney catalog and other places. They may last longer than a repack with stainless wool. I have never tried them. You may have ended up with aftermarket harley look alike. I have a set of Road King mufflers on the shelf but they have almost nothing in them to reduce the sound and it turns out they are after market ones you can look straight thru.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- JBz
can you see all the way thru them or is there a washer or something like that in there???????? jb
- Motowalt
Sounds like your FLH mufflers may have been cored by the previous owner to make them louder.
I installed a pair of Sportster mufflers on my 78 and it isn't very loud at all, about the same as the stock horseshoe muffler.
Try a new pair and see if that makes a difference, they are inexpensive.
Secondly, I always wear earplugs when riding, not just to protect against exhaust noise, but windnoise. They make a huge difference in lessening fatigue on long trips.
- BlueThunder
Packing info article:Offcenter wrote:Muffler packing material? First I've heard of it. Suggested source, Brian?
Thanks!
https://www.google.com/url?sa=t&rct=j&q ... 1466,d.aWw
Muffler packing sources:
https://www.denniskirk.com/moose/fiberg ... /25112.sku
http://www.jpcycles.com/product/ZZ33433
http://www.motorcycle-superstore.com/41 ... er-packing
http://www.amazon.com/Moose-Racing-Fibe ... B00230BCB6
http://www.bikebandit.com/aftermarket-p ... er-packing
http://www.dimecitycycles.com/vintage-c ... p-120.html
Or google "motorcycle muffler packing" for more sources.
...Brian
1977 GL1000 - Ox
1977 GL1000 - Ox
I used a two inch hole saw to drill the back out ( where the three screws would be). Didn't like the sound at all. Louder, but not the nice tone of the big vtwins. I put them back in. Imo, the stock Harley muffs sound nice. Do whatever you want to these, you still have a 250-300 cc cylinder making the noise. That's the same size as most lawn mowers. I haven't been able to find a set that has a good "tune."
did some PO knock out the baffles? OEM FLH pipes are actually fairly quiet... or, are you making noise where the header meet the muffler, or where the header meets the head?
Keep an eye out for the stock horseshoe system off a parts bike on local craigslist or
https://m.youtube.com/watch?v=mbmizeMSK3g
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- Offcenter
No, I've looked inside with a light. The original baffles are intact. The mufflers were billed as new take-offs. They were not even dirty inside when I got 'em. I get the feeling they were never used.JBz wrote:can you see all the way thru them or is there a washer or something like that in there???????? jb
I thought of that. But I don't do well with anything in my ears.wrote: Secondly, I always wear earplugs when riding, not just to protect against exhaust noise, but windnoise.
Thanks for the links. I'll look into muffler packing material. Seems like the best way to go at this point.
Thanks guys.
George in Jersey
76 GL-1000
77 Trail 90
76 GL-1000
77 Trail 90
If you can't take the internal baffle out you won't be able to use the muffler packing. Like someone already said those mufflers stock are pretty quiet. Maybe they are just "louder" than you are looking for. Almost sounds like the stock GL muffler is what you want.Offcenter wrote:snip...........
Thanks guys.
my thoughts exactly. Stock FLH mufflers are quite quiet (say that three times fast). So if they are really loud, I would look elsewhere for the noise in the system
- 9 Replies
- 450 Views
Last post by BlueThunder
- 12 Replies
- 3108 Views
Last post by Rambler
- 4 Replies
- 334 Views
Last post by Gowing
- 9 Replies
- 994 Views
Last post by winger27
- 34 Replies
- 1022 Views
Last post by 77Gowing
