head bolts
- FargoFour
head bolts
Hi,
When any of you have removed the heads do you reuse the head bolts or buy new?
thanks,
Bud.
thanks,
Bud.
70 CL450
84 GL1200 A
98 GL1500 SE
Where there's a will, there's a relative. - Carlton Johns
84 GL1200 A
98 GL1500 SE
- ianstaley
Re: head bolts
You should NEVER reuse old hear bolts, they are stretched when torqued down to the manufacturers specs. I learnt my lesson years ago on a Triumph I had, to tight to buy new ones as the old ones looked fine, re torqued the bolts, great 120 miles down the road one snapped on the Motorway (highway to the US friends). I spent a lot on that motor only to re spend it and a bit more on New Head bolts. Well they were studs, long ones in the triumph Cylinder goes over the the long studs then the head on top with nuts. Now if I have to have the head off new nuts and bolts always. and if you can get them ARP are the dogs nadgers or cahonas.
- Steve81GL1100
Re: head bolts
Only one problem..... Honda has discontinued the longer, M10x115mm bolt. The short M10x90 are still available at a list price of about 10 bucks apiece. I haven't looked to see if anyone like ARP offers replacements.
That said, I re-used all the bolts on my heads when I went through the 1100 last year prior to putting it back on the road after a 15-year slumber. No issues with torque or anything else, and still no issues after 1200 miles. Others probably have many times that mileage on theirs...
I've also done a lot of work on Honda cars, and in no case did Honda recommend replacement of head bolts in their OEM shop manuals. Hundreds of thousands of problem-free miles, and automotive heads are torqued tighter than our bikes.
Steve
Steve
Steve
1981 GL 1100 Standard, 81 Interstate bags, 84 GL1200 pegs, sometime National Cycle PlexiStar windshield
1996 BMW R1100R
2007 Piaggio X9 Evo500, wife's ride so she can keep up with the GL
1980 Vespa P200 (also wife's), restored, with custom paint, custom trim
1996 BMW R1100R
- rich3389
Re: head bolts
Generally, you should not re-use head bolts because most of them are torque to yield. But on the old wings, they are not torque to yield, and the manual does not say they need to be replaced.
When I did my heads, I just cleaned up the threads real good with a wire wheel, and re-used them.
1978 GL1000
- ianstaley
Re: head bolts
OKay I can live with that. as I said it is what I would do, it isn't de facto.
- Bugdaddy66
Re: head bolts
Generally speaking, standard reusable head bolts were the norm for years and manufactures have been changing over to torque to yield design. The main reason is the newer style negates the need for re torquing as the clamping force is in the stretch of the bolt, saving money at assembly. It is also less effected by things like thread condition, lubrication and drag of bolt on head. If the original design was not stretch type bolts, the expectation was they would be reused. Never reuse torque to yield design, you cannot achieve proper clamping force again. I did a diesel this week, spec was 36 lbs, then 90 degrees 3 times. I have to use a 6 foot bar for that last 90!
Todd Logan (Bugdaddy66)
"Never argue with a moron, they'll always drag you down to their level and beat you with experience."
1978 GL1000 Daily commuter (SOLD)
1981 XS650 Hot Rod play bike (SOLD)
2003 BMW F650CS (Wife Bike)
2009 BMW R1200RT
2009 BMW R1200RT
- Toehead
Re: head bolts
Remember, torque spec for the wings is assuming the threads and heads are lubricated with a good moly grease!
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
- rich3389
Re: head bolts
Does the manual actually say to use moly grease? I don't remember reading it anyway, it just says torque them down "wet". Was using Moly for headstuds in the 70's a normal thing? I just assumed by "wet" it meant some motor oil on the threads.Toehead wrote:Remember, torque spec for the wings is assuming the threads and heads are lubricated with a good moly grease!
1978 GL1000
- zman
Re: head bolts
I would measure them and check for straightness. Something I found on me wing the torque specs for the head is 44 foot pounds in the book, so while checking the valves I checked the head torque..keep in mind the bike had 9K original on the clock and never been cracked open.
I set the meter at 45 and every bolt clicked fast as if they were torqued higher on assembly. wonder if they didn't add a little after the 44 pounds and how much was it.
1980 1100 Interstate, 1978 GL1000
- rich3389
Re: head bolts
The reason for this is because of friction. The proper way to re-torque something is to back the bolt off a hair, and then re-torque to your value.zman wrote:I would measure them and check for straightness. Something I found on me wing the torque specs for the head is 44 foot pounds in the book, so while checking the valves I checked the head torque..keep in mind the bike had 9K original on the clock and never been cracked open.
1978 GL1000
Re: head bolts
Re: head bolts
I was told it's fine to reuse our head bolts.
So dats what I did. Oh well.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Re: head bolts
Gowing wrote:I was told it's fine to reuse our head bolts.
You did fine. These are not torque to yield bolts. They can be reused many times. On my race engine's I reuse them too.
- 12 Replies
- 841 Views
Last post by 5speed
- 11 Replies
- 402 Views
Last post by Voltaire
- 11 Replies
- 1146 Views
Last post by Sidecar Bob
- 4 Replies
- 219 Views
Last post by CYBORG
