Piston to valve clearance
My '77 GL has at least one blown head gasket (poor Nora). I think its been this way since I got it and just got super bad when she got a little hot on a recent ride. Coolant rolling out of the tail pipe bad. While the heads are off, I figured I'd get them decked and bump up the compression just a tad. I just need to know how much can be taken off without having clearance issues. I've read dozens of threads and web pages and haven't found anything remotely close to what I need. I know how to measure with modeling clay et al, but I'd rather not go through the hassle if someone has already done it, or otherwise knows where I can find that value.
Thank you,
Gator
Thank you,
Gator
Re: Piston to valve clearance
Can't answer you question. But do be aware that as you remove material from the head you change cam timing.
I took 0.025" off 77 heads, but put them on a 1200 block. I had the pistons notched on the intake side to be sure they would clear. Pistons are less domed on 1200's. I couldn't find data either. I think I calculated that I lost 0.6 degree in cam timing with the shave. I recently advanced the cams to get that back and a little more. So far, so good.
- oldwings 78
+1 Robin. I would only have the machine shop take enough material off the heads to get them flat again. I do want to know how the valve timing can change by milling a few thousandths off. The number of cogs on the crankshaft and camshaft are the same, just a few thousandths closer together right?
Terry
EDIT oops, duh! I read my post and answered my own ???????? (a few thousandths closer)
Terry
"A man who is good at making excuses is rarely good at anything else" Benjamin Franklin
"A man who will sacrifice freedom for security deserves neither" Benjamin Franklin
'78s are the best looking GLs Just ask Doc
- chewy999
oldwings 78 wrote:+1 Robin. I would only have the machine shop take enough material off the heads to get them flat again. I do want to know how the valve timing can change by milling a few thousandths off. The number of cogs on the crankshaft and camshaft are the same, just a few thousandths closer together right?
Terry
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
Terry, the few thousandths off the head move the cam gear backwards. Because the teeth on the belt remain fixed. I calculated it as 4.7" dia of cam gear * pi = 14.766 circumference of cam gear---- 360 / 14.766=24.38 deg per inch---- 0.025*24.38= 0.6095 degrees at the cam.
That would be 1.2 degrees at the crank.
Interestingly, that same 0.025 at the cam keyway translates to is closer to 4 degrees because the cam shaft is so much smaller.
Now, I've been wrong before, so.............
ericheath wrote:Terry, the few thousandths off the head move the cam gear backwards. Because the teeth on the belt remain fixed. I calculated it as 4.7" dia of cam gear * pi = 14.766 circumference of cam gear---- 360 / 14.766=24.38 deg per inch---- 0.025*24.38= 0.6095 degrees at the cam.
My head hurts, that's too much math. Put a degree wheel on it in stock form and then after moving it. That will tell you exactly where it is.
Degree wheels need to be calibrated and set properly, and you have to know how to use them. Math is exact. I've been in school 50 years, but I'm still in fourth grade. So my math could be wrong. My numbers could be off a little as I haven't checked my calipers for a while. One of these days I'll pick up a wheel and learn to use it.
Right, if the idler took up the slack form both sides of the belt, no change, I get it. I do like me some math, but I'm not the slightest bit worried about 1-2 degrees of cam timing, its never that accurate anyway. Unless you have an adjustable cam sprocket, you'll always be off a bit. What I am concerned with is finding an answer to my question. So if I don't get my answer here, you can bet I will find it myself and report back. Thanks for your responses.
Gator
Gator
I think you will have to. I've been hanging around here for ten years and don't remember anyone reporting it, unless Oldboy did it on his 1100. That wouldn't answer your question for a 1000. My gut says it will be okay, but you'd be best to use some clay and model it at the stock spot. That would give you an idea if you can go very much. It would give it some more punch at the lower rpm.
ericheath wrote:Degree wheels need to be calibrated and set properly, and you have to know how to use them. Math is exact. I've been in school 50 years, but I'm still in fourth grade. So my math could be wrong. My numbers could be off a little as I haven't checked my calipers for a while. One of these days I'll pick up a wheel and learn to use it.
LOL, there is math when using a degree wheel too. But after so many you can do it pretty quickly.
Degree wheel and a dial caliper is all you really need. Positive piston stop is useful too. But about the only way to use that right is to set the wheel up before installing the heads.
Yeah, that's what I figured. I thought I read about it once here, but there was no solid number given. I don't mind doing it myself, but it will be my first time, so we'll just see how it goes. I'll have to measure the combustion chambers as well, to see how much shaving will increase the CR. More math, but at least I've done that one before.
On another note, I think 9.2-1 CR is a little on the weak side. I'd really like to have it up around 11-1, but any increase will be just fine with me. My ignition is pretty hot (electronic ignition and MSD coil) so I think she'll be OK in that area. She woke right up when I trashed the original setup. Very excited to get her back on the road, and its nice to know this gasket may have been the source of my slightly rough idle and smokey (steamy?) start ups. Also going to hit some cosmetic issues, fix the neutral switch, lights, mirrors, repaint exhaust and wrap the headers befor buttoning her up again.
Thanks again,
Gator
Thanks again,
Gator
Easy way to raise compression. Bore the cylinders.
This also unshrouds the valves some.
How is that an easy way to raise the CR?
Remove engine, split engine and diassemble, send engine to machine shop, buy new pistons and rings, buy a bunch of new seals and gaskets, reassemble engine, reinstall engine, rejet carbs. Not to mention, I would still have to do all the work I have to do anyway, to fix the head gaskets. Not following you here.
Gator
Gator
Gator417 wrote:How is that an easy way to raise the CR?
Take the same pair of heads. Rather than put them on a 1000 you can put them on an 1100. You can put them on a 1200 too but you have to open the valve reliefs in the pistons.
Yes I did say bore them out. And that would be more work. But swapping lower ends is pretty easy.
