Are there any good posts on replacement of the clutch cable with the engine in the bike?
78 GL1000
Thanks,
Ken L.
Clutch cable replacement
- Ken L.
2005 GL1800 Dark Grey Metallic, \ CSC Trike
1975 GL1000 Red (Owned since 1980)(Given to my other son)
1976 GL1000 Red (being restored)(Given to the Jones boys)
1978 GL1000 Black, dressed (Given to my son)
1985 Aspencade bought brand new, traded and now back home.
Ham Radio W8BUY
Re: Clutch cable replacement
Tape old cable to new cable when you pull it out. I think I taped the top of the new cable to the bottom of the old cable.
Not that I am aware of, but proper routing is important. The cable should enter the small opening just forward of the choke knob and pass in front of the headstock through the Right hand triangular frame opening, then along the inside edge of the right hand frame tube. There should be a cable suspender about mid way back. The worst spot is snaking it through between the frame and the fuel tank. I often take the brake switch wires apart and remove them so as to not tug and pull on them excessively. No sharp turns on the cable.
- Placerville
Although you might cringe at the following suggestion, it's actually easy to do. When replacing throttle and clutch cables, I find it very 'freeing' to remove the top shelter. When removed, you'll find you have TONS of access to previously inaccessible areas and your cable replacement will be a breeze.
1. Pull the pins on the left and right side false tank covers and remove them. (Leave the top shelter lid in place.)
2. Disconnect the connector for the fuel gauge to the harness.
3. Remove the four bolts holding the shelter to the frame.
4. Remove the air box.
5. Disconnect all of the harness connectors on the left side of the shelter.
6. Lift off the shelter and be amazed at how much access you now have to your cables.
- RogueCreature
Yep...that seems to be the proper case...i did this when i replaced push pull cables...clutch snapped the other day, I guess Its time to take the top housing off again. might do speedo and tach while im at it as well. last time i disassembled too much of the false tank lid/gas guage. i remember thinking i should just pulled the connector off but i didnt see it at the time, hopefully i can see it this time.
1977 GL1000
Some have said i have the patience of a rock. I know myself to well to say the same.
- OhioBill
- My Album: http://www.ngwclub.com/gallery/v/wingmans/OhioBill
Look up Puffy page and how he routed his clutch cable. It seemed to make sense. It is not the stock routing. The most difficult part of your, I suppose, is the attachment at the motor. If you have a lift table it is not too bad. Still requires a lot of swearing as you work in the close quarters under the frame.
OhioBill
Retired and Loving it.
1979 Black (to be restored)
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
1979 Blue (Sold)
1993 blue 1500 Sold
1976 Restoring
- scootsx2
Its easy to replace the clutch cable with the engine in the bike. As mentioned in earlier posts, just be careful of the cable routing.
1975 GL1000 Sidecar Outfit
2001 GL1800 MotorTrike
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
2006 Vespa LX150
195x Solex 1700
196x Solex 2200
St. Louis, MO
The dude abides.
- jdvorchak
Personal preference tip here. I lube even new cables before I install them. Make sure the ferrule at the clutch lever is lubricated with high temp grease and confirm that it doesn't bind moving through the clutch lever. Clean and lube all moving surfaces of the clutch lever and pivot pin again with a very thin coat of high temp lithium grease.
I use High Temp grease not because it gets hot up there, but so it doesn't melt in the sun and start dripping.
Amateur Radio Station WW9L
2021 HD Triglide
2008 HD Dyna Low Rider
83 KZ1100L1 Son totaled it
83 KZ550LTD Shaft sold
John
2021 HD Triglide
John
