Bad stator
Re: Bad stator
salukispeed wrote:Out of fear of some aftermarket parts I ponied up the dollars for the Mother Honda one and so far so good but It was a battle to spend the money. Is there a good way to evaluate one besides resistance check and possibly use a megger to verify the insulation. The coil resistance is so low a normal ohm meter will not do a good job and I do not know of any dynamic check that would be available to most of us. There are likely some real electrical wizards in this group that may have an idea.
That works as long as you can find one. Honda no longer makes even the 1200 stator. There are some out there though.
Re: Bad stator
electrosport was the seller. But where was it manufactured. Sometimes it's just better to bit the bullet, and go OEM
kingzero
Re: Bad stator
Post by kingzero »
Got the motor out and pulled the stator.
This is what I found. I had pinched one of the wires between the stator and the cover.
Lesson learned. Electrosport is in the clear. The stator tests good while on the bench so I will wrap the damaged wire and reinstall. Then I will retest it after it is in the cover.
You may want to pin the photo for others to learn from.
Haste makes waste.
1975 GL1000 Teal ( Done )
1978 GL1000 Blue
1982 XV750 Virago (Sold)
1965 Honda CA100 (Sold)
1964 Honda CA110 (Sold)
2011 Yamaha FJR 1300
CWC 963
VJMC 10925
Re: Bad stator
that's good to know. glad it worked out that way
skydog
Re: Bad stator
#20
Post by skydog »
Oh!I hate it when that happens!Don't feel too bad,the 84 is in pieces again.Seems when I put in new fork seals,i dinged one.
75 naked "Blue Streak" gone
78 fairing bags "Brownie" 4 sale
80 standard project 4 sale
84 Standard, Vetter bags "Horse with no name"
85 Interstate gone
84 aspy
86 aspy
"When the day comes to settle down,who's to blame if you're not around?You took the long way home"
kingzero
Re: Bad stator
#21
Post by kingzero »
Bike is back together and charging at 14.3 volts.
Ta Da.
1978 GL1000 Blue
CWC 963
VJMC 10925
kingzero
Re: Bad stator
#22
Post by kingzero »
5 hours from start to finish.
1978 GL1000 Blue
CWC 963
VJMC 10925
kingzero
Re: Bad stator
#23
Post by kingzero »
Hey Cyborg. You going to Stockbridge?
1978 GL1000 Blue
CWC 963
VJMC 10925
Re: Bad stator
#24
Yes I am. It is on the 21st of Sept. Some are saying the 14th. But it is the 21st
kingzero
Re: Bad stator
#25
Post by kingzero »
I put the poster on the all runs page.
1978 GL1000 Blue
CWC 963
VJMC 10925
Re: Bad stator
#26
I saw that. Very good Idea. What time you expect to be there?
kingzero
Re: Bad stator
#27
Post by kingzero »
Around noon. I will ride down with the Vintage Rice Burners as we have a spot assigned on the lawn.
1978 GL1000 Blue
CWC 963
VJMC 10925
Re: Bad stator
#28
I'll look for ya
tlbranth
Re: Bad stator
#29
Post by tlbranth »
kingzero wrote:Hey Cyborg. You going to Stockbridge?
Sounds like a Simon & Garfunkel song
Terry
Don't own a Vanagon
Don't work at Boeing
Life is good
1999 GL1500 SE
2002 Honda VT750 "ACE"
1970 CB750
Re: Bad stator
#30
