And close-ups:
The left side took probably a total of an hour. The method I used was to start with a red ScotchLok pad in the 1/4" die grinder at moderate speed to grind through the old remains of clear-coat and corrosion. Follow that with manual rubbing around the circumference with a red ScotchBrite pad, followed by wet-sanding with 400, 600, and 1,000 wet-or-dry. After a good rinse, I chucked up the buffing pad from a 3M headlight restoration kit (the pad has a waffle surface), smeared a generous coating of Mother's Mag Polish on the fork, and went at it. After a few minutes I buffed off the remains with a microfiber towel and here's where it sits. It's not "show-chrome" perfect, but then neither is any of the rest of the bike. I'm pretty happy with the hand-rubbed nature of the shine.
Now on to the other side...
Steve
