Gasket for clutch adjustment cover/lifter cover?
- SMLE
I can't find the little cover that you remove for doing a basic clutch adjustment on the parts fiche. I think it's caller the "lifter cover". The gasket on mine was not in very good shape the last time I did a clutch adjustment and I'd like to just get a new one. Can anybody tell me where to look for it, or give me the part number?
Thanks.
Thanks.
"Like a rich armour worn in heat of day that scalds with safety..." ATGATT.
"If you can park it and walk away without looking back to admire it, you bought the wrong bike."
1976 GL1000 "Irma".
1976 GL1000 "Irma".
- chewy999
Re: Gasket for clutch adjustment cover/lifter cover?
Hi there,
You didn't say what bike it was for, maybe they are all the same, but try this link, am I in the right area?
http://hondapartshouse.com/oemparts/a/h ... utch-cover
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
Current bikes
- SMLE
Oops.
It's for my 1976 GL1000. And it's the gasket for the small lifter cover that you remove to do basic clutch adjustments. Not the clutch cover itself. I found that gasket and have it saved to my wish list.
1976 GL1000 "Irma".
1976 GL1000 "Irma".
- chewy999
Try this link, it's for a 77 model, the site didn't go to 76!
Not really sure what you are after, but sure someone here will be able to help if I can't.
http://www.hondapartshouse.com/oemparts ... -gearshaft
Previous Rides,
Current bikes
Current bikes
- SMLE
Close, but no cigar. I went to that site and searched there.
I'm looking for the gasket for this;
The manual refers to it as the "lifter cover."
1976 GL1000 "Irma".
1976 GL1000 "Irma".
- Norbert R
I just cut one out of 5mm Neoprene foam/rubber, works perfect. That cover is mainly a dust cover so pretty much anything will do the job. The Neoprene is very compressible so that helps.
I used roof sheeting washers that have a rubber backing for the bolts.
- SMLE
Well I finally found the cover. I had to go page by page, they hid it on the "HANDLE LEVER / CABLE / SWITCH" page of the fiche. There is no separate part shown for the gasket and the cover is not available.
1976 GL1000 "Irma".
1976 GL1000 "Irma".
- chewy999
Glad you found it, Part of the fun looking and sourcing parts, maybe the neoprene idea is the way forward if it's only a dust seal. Good luck.
Previous Rides,
Current bikes
Current bikes
- Kroosa
I have made the same journey. It's no longer available. You can find good used ones off of parts bikes, but actually I admire the neoprene idea.
Ken R.
2013 BMW K1600 GTL
2013 CB1100
Several 75 & 76 GL1000's,
including a few LTD's, &
other early Hondas.
2013 BMW K1600 GTL
2013 CB1100
other early Hondas.
- SMLE
Neoprene or an O-ring the right diameter and glue it to the cover with Yamabond.
1976 GL1000 "Irma".
1976 GL1000 "Irma".
- 268 Views
Last post by odyssey
- 17 Replies
- 583 Views
Last post by ifm61
- 6 Replies
- 3140 Views
Last post by propav8r
- 13 Replies
- 468 Views
Last post by wannabridin
- 4 Replies
- 382 Views
Last post by Sidecar Bob
