New Ethanol rules
New Ethanol rules
There was a item on the Today show this AM.
It was said that the government is going to raise the limit on how much ethanol can be in fuel. It is now 10%.
The small engine manufacturers were screaming about how it would kill engines in boats, lawn movers, chain saw, etc, etc.
How would this effect the MC community ?
78 GL1000 Original Owner 131k
Re: New Ethanol rules
the american motorcylist association magazine had a long article on that this month. Seems they want to raise it to 15%. as it stands now the law states that the pumps must be clearly marked 15%, and that the station must also have a 10% pump. Its not that hard to remove the ethenol from the fuel yuou buy if you want to go that route. however 10% is not a real problem, except for lower MPG
- NewWinger
That's why the small engine industry is chomping at the bit. I always run my yard and grounds machines dry before I put them away for the season which includes running Stabil through them on the last run.CYBORG wrote:the american motorcylist association magazine had a long article on that this month. Seems they want to raise it to 15%. as it stands now the law states that the pumps must be clearly marked 15%, and that the station must also have a 10% pump. Its not that hard to remove the ethenol from the fuel yuou buy if you want to go that route. however 10% is not a real problem, except for lower MPG
SNIP Comment removed.
NewWinger apparently you are thick headed and it takes a baseball bat to get through to you. Out of respect and courtesy I tried doing this in private but you do not heed the warnings. This is my house, my rules. You seem to enjoy acting like a teenager trying to push the boundaries constantly. That does not work here. Last warning and then you are history. Whiskerfish
Kenny
Illegitimi non carborundum
'77 GL1000 my first bike @58
- JBz
ethanol. a total waste of energy. Farmers and most people know that. Monsanto and others are the culprit. JB
- salukispeed
Last article I read claimed that even the EPA was firmly against the higher percentage. That 10% was as far as the systems can tolerate and the problems that are associated with 10% are terribly agrivated with the additional 5%. So where does the pressure to bump it up again come from. Luckily I can still buy but E0 without going too far out of my way for weed eaters and blowers. Even my 2012 Honda snow blower states 10% maximum.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
Is it possible that the corn growers have been putting a lot of pressure on congress ?salukispeed wrote:Last article I read claimed that even the EPA was firmly against the higher percentage. That 10% was as far as the systems can tolerate and the problems that are associated with 10% are terribly agrivated with the additional 5%. So where does the pressure to bump it up again come from. Luckily I can still buy but E0 without going too far out of my way for weed eaters and blowers. Even my 2012 Honda snow blower states 10% maximum.
Haven't corn prices gone thru the roof since this all started?
- pierce
- My Album: pierce
I don't know much on this subject as Wisconsin has non ethanol available at most stations, but what I do know is that the other day I put in regular and I panicked at how my mpg suffered. it also seemed to develop a slight hesitation, like it would miss every few minutes. thought perhaps I was developing a carb issue, but as soon as I went back to non ethanol it was fine. the extreme cold weather could also have something to do with it as it was about 6 degree.
1976 GL1000
1978 Gl1000
1978 Gl1000
- Brant
- Board of Directors
I have always used 10% in my 1100 and do not notice any bad effects.
according to the AMA article, there are only a few stats that now already have E15, at limited locations. i have not seen it, that i recall. but it MUST be clearly posted at the pump. and if it ids a blended pump, they must also have a pump that is not blended for fuel that is E0 or E10. those costs to the stations alone might slow the E15 advance
- milesoffun
I swear I read recently where the whole idea of ethanol was under review due to the now abundant supply of oil as well as the problems growing all that corn for fuel rather than food has caused. Did anybody else see that?
MilesOfFun
80 GL1100 - Yellow (Got wet due to Huricane Sally - gonna give it a try!)
83 GL1100I - Blue (Got wet due to Huricane Sally - but gonna give it a try!)
- bubblerboy64
Could we ever just admit "we tried it and it didn't work"? Seems like that's impossible
John Heckman
Central Pa
jehdds@hotmail.com
2010 Triumph Bonneville SE
2012 Vespa GTV300ie
2012 Harley Sportster Custom
2014 Honda CTX700 DCT
Central Pa
jehdds@hotmail.com
2012 Vespa GTV300ie
- NewWinger
Thanks you for the respect and courtesy shown this time too.NewWinger wrote:That's why the small engine industry is chomping at the bit. I always run my yard and grounds machines dry before I put them away for the season which includes running Stabil through them on the last run.CYBORG wrote:the american motorcylist association magazine had a long article on that this month. Seems they want to raise it to 15%. as it stands now the law states that the pumps must be clearly marked 15%, and that the station must also have a 10% pump. Its not that hard to remove the ethenol from the fuel yuou buy if you want to go that route. however 10% is not a real problem, except for lower MPG
However, only one acting like a teenager is the one who posted a blatant insult PUBLICLY and that is YOU!
I'm surprised that this is so unbecoming of a gentleman of your retired rank.
I was not sarcastic, was not disrespectful or insulting but I saw the discussion going south towards politics. Nothing wrong with eyeing the boundery to stay out of it, is there?
Kenny
Bye Bye
- tomk1960
I was under the impression that E85 could only be used in vehicles with engines designed to run on that fuel. A few years back, "60 Minutes" did a piece all about E85 and how it was a great alternative to using regular fuels. They also got into some of the specifics regarding why certain vehicles could or couldn't run on it. I guess as long as the 10% fuel is offered alongside, we have no worries. Unfortunately, there are no ethanol-free pumps within reasonable driving distance of me else I would definitely fill up all my bikes with it at the end of the riding season.
1986 VFR750F Interceptor
1978 Honda GL1000
1978 Honda GL1000
The nearest ones for me are 40 miles or better so I have to run the crap gas. My Bud's place in SC has real gas places all around him. It is really a shame that they have forced this on us. It costs more to make and costs more to operate. I loose 2-3 mpg on the Wing with it. Not sure about my Truck as I have never run real gas in it that I recall
- 653 Views
Last post by RB
- 7 Replies
- 1069 Views
Last post by duke182
- 8 Replies
- 338 Views
Last post by Sidecar Bob
- 16 Replies
- 3322 Views
Last post by mikenixon
