Valve keepers?
Valve keepers?
Hello again,
Do you think I have enough compressed to get keeper out?
I can't seem to get them to move,
Thank you
Thank you
- image.jpg (69.74 KiB) Viewed 496 times
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
2000 moby blaze 40cc
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Re: Valve keepers?
i know your new to this, i'll give you an easy way to get them out. lay the head on a table with a rag under it pushing up against the valve. take a deep socket the just fits the top of the spring . hit the top of the socket with a large hammer. the keepers will pop out. might take two hits. and watch where they go. they should wind up inside of the socket
Re: Valve keepers?
Came right off after two wacks, old seal and seat looked pretty good I guess.
Thanks dave
Thanks dave
- image.jpg (82.5 KiB) Viewed 486 times
- image.jpg (49.57 KiB) Viewed 486 times
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
Re: Valve keepers?
those seats need lapping. get some lapping compound, put some on the valve face, install it in the head, and turn it side to side with slight pressure on the face of the valve. thay make a tool for that. what you want is an even smooth surface on both the valve and the seat after you have done them all, and the springs are installed, turn the head face side up and set on a table. fill the dome of the head with a liquid, til it covers the valve face. let it set a minute or two, and make sure the liquid doesn't leak past the valve seal. if not, all is good. if it does, take it apart and lap some more
- salukispeed
Re: Valve keepers?
That trick with the socket works real well. I usually cover the head with a rag before whacking the socket just to be sure everything stays in a place so I can find it. Learned when I dropped the socket. Also the socket could easily drive the retainer far enough to smash the seal enough to damage it and it will still look fine so you might consider new ones to be sure. Easy now and a bummer once back together.
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
Re: Valve keepers?
i would always replace the seals once your that far in. just a good practice
Re: Valve keepers?
One down, lapped the heck out of it and lubed a new seal and put it on.
I actually used the wack method to put the keeper back on.
Only seven to go.
Only seven to go.
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- salukispeed
Re: Valve keepers?
Never tried putting one back together that way.
Honda 72 CL100 sold
1970 CT 70
1970 CT 70
Re: Valve keepers?
nor have i. interesting idea
Re: Valve keepers?
Actually I used the compressor to put one keeper on then with the head on floor I
used the socket and wacked it and the other one fell in. I think the heel of my foot
helped too. Being barefoot I could feel the spring bottom out. I think I'll try
The foot method next. Only six to go.
Chiwawa power!
Chiwawa power!
- image.jpg (67.89 KiB) Viewed 460 times
Dave
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
1975 GL 1000
1980 XS650
1981 ct110
1972 F7 KAW 175
Chihuahua (Ellie)
Chihuahua #2(Blaze)
- gadelsperger
Re: Valve keepers?
Be sure to clean out all the abrasive from the lapping compound before reassembly.
George in Rancho Cordova (Sacramento is a suburb) CA
- salukispeed
Re: Valve keepers?
Also be careful that the retainer does not contact the seal when it is compressed with the hammer strike as it can be easily damaged and nolonger work.
Honda 72 CL100 sold
1970 CT 70
1970 CT 70
