83 clutch B plate
- jgenaw
- Tin Member
83 clutch B plate
Hi Guys. I hope someone can give me some advice on this. I'm replacing the clutch in my 83 Interstate. I've been looking on here and the info I've been getting is priceless. I did run into 1 problem though, when I pulled the clutch basket out the B plate was in pieces. I read on here, I think, about removing it and inserting 2 more clutch discs instead. Wouldn't it be a better fit replacing it with 1 disc and 1 plate?
- clutch plates.jpg (100.57 KiB) Viewed 622 times
1983 Goldwing Interstate (work in progress)
Re: 83 clutch B plate
- jgenaw
- Tin Member
Thanks Sunnbobb that's the post I was thinking of. Apparently my steel trap of a mind didn't quite remember it correctly.
- bob
I've had an issue with my 1100 since I bought it two years ago. Sometimes when I'm first starting out, I get a loud buzzing sound from the clutch, and it's a bit grabby. It's been gettin g louder and more frequent in the last month or so. I'm worried that I'm headed for a bad day in my future. This could perhaps be what I'm hearing/feeling?
Bob
Bob
75 GL1000, blue-green, 49K
81 GL1100 basket case
86 Aspencade, runs good, no clutch
82 Standard, rider
84 Standard, finally! Project bike, Thanks again, Dave...
I AM the man from Nantucket.....
82 Standard, rider
- alwing17
- Exceptional Member
I hope you find all of the missing rivets! Sometimes one will get sucked into the scavaging oil pump and tear it up,causing hard shifting and hard to find neutral when at idle.The purpose of that pump is to remove oil from the clutch sump when the engine is running. With it not working,the clutch plates are immersed in an oil bath and can't release properly.Unfortunally,the only way to check the pump is to remove engine and rear cover to gain access to the pump.
Like this one out of Zonker a few years ago...
1975 GL 1000 "Street Fighter"
1976 GL 1000 "Screaming Yellow Zonker"
1976 GL 1000 Sulfur Yellow x2
1981 GL 1100 "Crown Royal"
1997 GL 1500 Pearl Sapphire Black
1977 GL1000 Cirrius Blue
1977 GL 1000 Skidmark build
1976 GL 1000 Limited
2003 ST 1300 Silver Streak
(And those are just the Gold Wings! With an exception..)
Team 898...25%er...*Beverages Consumed
Team LTD...1/6th'er...* Even more beverages consumed
- Motowalt
Hey Alwing17, I think you're onto something here...alwing17 wrote:I hope you find all of the missing rivets! Sometimes one will get sucked into the scavaging oil pump and tear it up,causing hard shifting and hard to find neutral when at idle.The purpose of that pump is to remove oil from the clutch sump when the engine is running. With it not working,the clutch plates are immersed in an oil bath and can't release properly.Unfortunally,the only way to check the pump is to remove engine and rear cover to gain access to the pump.
I wonder if the above is the cause of my current problems in a 76 Gl.
I just rebuilt the tranny because it kept popping out of first gear (found and replaced badly worn dogs and 1 fork), but I didn't think to look at the scavenging pump before putting the engine back together.
After reassembly I have problems with:
-can't find neutral at idle
-hard shifting
-clutch slipping
So I pulled the clutch, and everything was in spec (plates, springs) except for some noticeable wear on the basket fingers which I smoothed a bit with sandpaper (motor in frame, so I couldn't pull the basket).
I also found the original B plate had been replaced with an updated version with two rows of teeth...
So maybe the original B plate had disintegrated and the PO replaced it???...
Do you think a rivet lodged in the scavenge pump might have caused the PO's original problem of rough shifting to wear down the dogs on first gear?
- Ericson38
Can someone explain the difference between the GL1100 B plate in his picture and the older pre-'78 dreaded GL1000 B plate?jgenaw wrote:Hi Guys. I hope someone can give me some advice on this. I'm replacing the clutch in my 83 Interstate. I've been looking on here and the info I've been getting is priceless. I did run into 1 problem though, when I pulled the clutch basket out the B plate was in pieces. I read on here, I think, about removing it and inserting 2 more clutch discs instead. Wouldn't it be a better fit replacing it with 1 disc and 1 plate?
Charlie
1978 XR75-to get the mail
1983 GL1100-Standard-Blackie
2000 GL1500 SE-Whitey
Previous Bikes-
1977 GL1000 (10 years old at purchase with 100K miles)
1973 CB750 (purchased new, put 35K miles on it)
1972 CB750 (purchased new, put 12K miles on it)
1971 CB500 (purchased 1 year old, put 5 K miles on it)
Previous Bikes-
- Motowalt
http://www.wingovations.com/#/clutch-pl ... 4539741861
ooops, it's pretty much the same info posted by sunnbobb above...
- Ericson38
Had seen that one prior, not seeing the difference between the early version and the later GL1000 (same as GL1100 '83) version. Old Fogey stated that the early one had a different construction, at (http://www.ngwclub.com/forum/viewtopic.php?f=1&t=50069).Motowalt wrote:http://www.wingovations.com/#/clutch-pl ... 4539741861
Charlie
Previous Bikes-
Previous Bikes-
- alwing17
-hard shifting
-clutch slipping
Do you think a rivet lodged in the scavenge pump might have caused the PO's original problem of rough shifting to wear down the dogs on first gear?[/quote]
Easy to check..Pull the clutch cover off on the center stand and see how much oil comes out..More than a few drops...Scavenging pump is not doing it's job. I only found out mine was bad when I did the 1200 clutch conversion w/the motor on the bench. I had replaced the stock clutch with a used one and a good B plate..Worked great for about 5 mins,until I rode it about 5 miles,then the hard shifting and inability to find neutral at idle came back.
-hard shifting
-clutch slipping
- Tin Member
You need 2 metal ones.
One to go where the clutch plate B was and one at the end of
Clutch pack.
I can't remember which end but it is important.
If you assemble clutch pack it should be evident which end.
I did my 83 gl1100 this June.
Make sure to remove and clean oil pick up on right side of motor.
You will find brass rivet remains in here.
Flush with clean oil to remove all nasty bits.
Clutch pack.
- Motowalt
"Easy to check..Pull the clutch cover off on the center stand and see how much oil comes out..More than a few drops...Scavenging pump is not doing it's job. I only found out mine was bad when I did the 1200 clutch conversion w/the motor on the bench. I had replaced the stock clutch with a used one and a good B plate..Worked great for about 5 mins,until I rode it about 5 miles,then the hard shifting and inability to find neutral at idle came back."
Alwing you are right again....I pulled the clutch cover and LOTS of oil drained out...(luckily I had a pan beneath it when I did...)
So it looks like I'll be working on the scavenging pump next...oh boy...
- 4 Replies
- 669 Views
Last post by Sidecar Bob
- 8 Replies
- 712 Views
Last post by fitscott
- 1 Replies
- 111 Views
Last post by flyin900
