Front Blinkers not working
- SamIAm
- Tin Member
Installed my new (aftermarket) 7v regulator couple of days ago....no problems, but then decided to do some clean up work of the wiring harness in the headlight area. The last owner had bags, windjammer, etc and I removed them awhile back but didn't take a lot of time with the wiring and just now getting around to doing a little clean up of splices, etc. Now I have problems. I only disconnected and reconnected one wire at a time and am pretty sure everything is as it was but now the rear turn signals work but the front turn signals don't. Here what happens, when I turn on the signal, the rear signal blinks but the front signal (which is lit as a running light) goes out but does not flash. Same thing on both sides. This seems really familiar but if I had the problem before I don't remember what I did to fix it. Anybody??? Help?? Thanks.
- Placerville
Re: Front Blinkers not working
Go here and download a color wiring harness diagram. It will help you. They refer to it as: "Honda Goldwing GL1000 1975 to 1977 Color Schematic-49F70.jpg (603.18 kB)"
- ritalz
Off subject. Sam, are you the one that sells parts on St Louis cl? Have not been to your neighborhood lately but have family in Patterson.
- taylorsel
On subject.
Look for your ground I had the same problem and it was a ground issue 78 and eirlier front turn sugnals are grounded to the light fixture through the stem and headlight holder and through the headlight bucket. make sure you have good connections through out and in the green wires on the harness.
STEVE LOGAN, 1979 GOLDWING, 1978 GOLDWING, 1976 GOLDWING
- SamIAm
- Tin Member
ritalz....not the one selling parts on craigslist but give me a yell sometime you're in the area. Got some really good bike ridin' area down here. Patterson's a nice area.
- SamIAm
- Tin Member
You nailed it taylorsel.....it hit me in the middle of the night last night. I haven't remounted my headlight yet. Didn't think about it as I was just cleaning up wiring and decided to test before I put the headlight back on. I knew it seemed familiar....think I've made the mistake before. Sure appreciate the post. This CRS syndrome is for the birds.
- Recycled Roadkill
And it only gets worse. Trust me.SamIAm wrote:This CRS syndrome is for the birds.
Bob Gill
'77 Honda GL 1000 Black Mamba (Sold)
- 7 Replies
- 344 Views
Last post by Jonesz
- 346 Views
Last post by tallnwise
- 20 Replies
- 967 Views
Last post by CYBORG
- 7 Replies
- 319 Views
Last post by Dr. Frankenstein
- 8 Replies
- 564 Views
Last post by pidjones
