just lights up the light - correct ?
I forgot to hook it up and I am in NO mood to drop the motor to hook it up right now
My chopper ain't got no stinkin' N light so I'm use to not having one
Come this winter I can attack it along with everything else I want to do (as long as I don't blow yet another head gasket)
On a positive note - my Dyna ignition system was spot on even after pulling it to resurface the heads. 3/4 dead one 2/1 just needed a slight tweek.
New luggage setup is almost done, just need to install new digital meter assembly and shoot some paint.
Neutral switch ------
- CharlieP
Growing Old is Mandatory ** Growing Up is Optional
http://www.ngwclub.com/gallery/v/wingmans/Chasdog/
- Placerville
Re: Neutral switch ------
Yes.CharlieP wrote:SNIP..."just lights up the light - correct ?"
- roncar
No.CharlieP wrote:SNIP..."just lights up the light - correct ?"
It is also a part of the starter circuit. With it disconnected, you will have to hold the clutch in to engage the starter (assuming your clutch switch works.)
- CharlieP
that's no biggy for now - Thanks guys
- Placerville
.....and I did not know that! Thanks roncar.
- chewy
If you're resourceful, you can get at it without pulling anything... http://www.ngwclub.com/forum/viewtopic.php?f=9&t=24019
you can tell how good a mechanic is by the size of the hammer he carries
'75 Retro/Custom
'75 Retro/Custom
- Hal
Stupid thing's a waste of effort anyway in my opinion.
I stripped mine when I had the engine out, took it apart, cleaned it properly and reassembled.
It worked fine for a while, now it seems to light almost entirely at random.
PITA.
PITA.
nor all your Piety nor Wit
1977 GL1000 in bits
1978 SR 500 Yam
Hal's Nalbum
1977 GL1000 in bits
1978 SR 500 Yam
Hal's Nalbum
- CharlieP
I went the Chewy route .......... just because
