return to idle
- Zinc Member
return to idle
Just got her running after rebuilding carbs, first time getting her to idle, idling at around 8-900 rpms, but when I blip throttle it takes about3-4 seconds to return to idle. my thinking is I need to lean out (screw in) idle mixture screws is that correct? any advice will be appreciated.
- chewy
Re: return to idle
bump, i have the same condition. started a thread and got no reply. i'll be watching for suggestions.
you can tell how good a mechanic is by the size of the hammer he carries
'75 Retro/Custom
'75 Retro/Custom
- RB
Re: return to idle
Could be a lot of things; sticky slides comes to mind first.
98 1500 SE..
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 DAILY RIDER sold her ((!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
79 IN BASKET PARTS FOR SALE
79 CLEANED UP AND SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 SOLD/PARTIAL REBUILD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
99 1500 SE SOLD
97 SE 1500 SOLD
83 SOLD
82 REBUILT sold!!!
81 REBUILT SOLD!!!
81 REBUILT SOLD!!
80 REBUILT SOLD
78 REBUILT SOLD
77 REBUILT SOLD
76 REBUILT AND SOLD
75 REBUILT SOLD
75 REBUILT SOLD
75 REBUILD SOLD
FAIR WINDS,
RB
- Recycled Roadkill
Re: return to idle
If everything on the carbs were done correctly and there's no other problems all you may need is to sync the carbs.
It's pretty easy but if you don't have the proper equipment it become a bit more of a problem.
Bob Gill
'77 Honda GL 1000 Black Mamba (Sold)
- salukispeed
Re: return to idle
The slide operation is terribly important but I do not believe they come into play until 1/4 throttle and up. A sticky mechanical advance under the points can cause this issue if it is slow to return to base timing. Vacuum leaks between the manifold to head or manifold to carb can affect idle stability. Proper sync can be critical also. what year is your bike?
Honda 72 CL100 sold
74 CB750 K4 nice driver
84 GL1200I work in progress
1970 CT 70
1982 GL500 Interstate
1970 CT 70
- Zinc Member
Re: return to idle
the bike is 1980 , idle is nice, just slow to return, but honestly this is my first goldwing, all other bikes were high performance sportbikes, maybe this is normal for a goldy I don't know.
Re: return to idle
Mine does that too (my carbs have been rebuilt and synced). Go to you tube and search for gl1100 exhaust and you will hear them coming back to idle slowly, Not anything like a quick sport bike.
- pistolpete
Re: return to idle
My.02.
Typically slow return to idle is a lean condition.
Try the idle down procedure first then be sure that the pilot screws are at 1.5 to 2 turns out from idle down.
If this doesn't work you may have an air leak into one or more cylinders.
Pete
Pete
Pistol
- Placerville
Re: return to idle
Prior to making carb adjustments, always consider whether you've done due diligence with the basics. (The basics are most often overlooked.) First, are you sure that your throttle cables are clean, lubricated and adjusted properly? Is the tube under your grip (that rotates on your handlebar) lubricated? Jumping to the more complex issues first without looking at the basics will always trip you up. Ensure that your cables and throttle tube are clean and lubricated and that the 'A' cable is adjusted so that a small amount of slack allows the carbs bell crank to return completely to a rest. Once that's done, start looking at other issues.
Re: return to idle
Pete beat me to it.pistolpete wrote:My.02.
Pete
- Zinc Member
- 156 Replies
- 4552 Views
Last post by Sidecar Bob
- 22 Replies
- 1191 Views
Last post by olchris
- 420 Views
Last post by Hal
- 4 Replies
- 343 Views
Last post by Recycled Roadkill
