Neutral Switch Fix
- Cakey
Neutral Switch Fix
I wanted a backup neutral switch in case mine failed. Had a spare that did not test good so gave it a shot.
1. Undo top and remove components
2. Soaked everything in vinegar and cleaned
3. Cleaned contacts with 600 paper
4. Assembled back together
5. Used gasket goo on thread. Oil, petrol and temperature safe
Hope it saves someone a couple of bucks in the future.
- Undid top in vice between some rags and used circling pliers. Unthreaded easy
- image.jpg (37.61 KiB) Viewed 494 times
- Clean all parts with vinegar soak or brake cleaner
- image.jpg (62.39 KiB) Viewed 494 times
- Clean contacts with paper
- image.jpg (33.66 KiB) Viewed 494 times
- Sit ball on top of cleaned brass housing
- image.jpg (26.47 KiB) Viewed 494 times
- Insert up into main housing
- image.jpg (26.99 KiB) Viewed 494 times
1975 Gl1000
- Cakey
Re: Neutral Switch Fix
Continue to assemble
- Insert spring into brass housing
- image.jpg (26.46 KiB) Viewed 491 times
- Gasket goo for switch thread
- image.jpg (34.56 KiB) Viewed 491 times
- Petrol, oil and temperature safe
- image.jpg (33.79 KiB) Viewed 491 times
- Gasket goo on thread
- image.jpg (31.37 KiB) Viewed 491 times
- Start threading in by hand
- image.jpg (23.69 KiB) Viewed 491 times
1975 Gl1000
Somebody else did this a year or 2 back..... Roncar??????
- Cakey
Finish assembly
Thanks Whiskerfish. I could not find anything in my searches only the discussions on running high voltage current through the switch which I was not keen on doing.
Anyway I had no test results to start with and now it's testing good.
- Tighten up with circlip pliers
- image.jpg (38.4 KiB) Viewed 491 times
- Wiped off goo
- image.jpg (25.07 KiB) Viewed 491 times
- Tested. Continuity when ball bearing not dpressed
- image.jpg (35.73 KiB) Viewed 491 times
- No continuity when depressed
- image.jpg (44.3 KiB) Viewed 491 times
1975 Gl1000
Yea I did all that burn off stuff and it lasted about a week. so I did it some more and some more and some more and eventually fried it for good.
Nice pictures, thanks for posting!
- roncar
Yeah 2 in shoptalk with reference to a third article I found on the web (no longer there but captured in the gallery.) Between those 3 and this one, cleaning the switch is easier than "accessing" the switch.Whiskerfish wrote:Somebody else did this a year or 2 back..... Roncar??????
http://www.ngwclub.com/forum/viewtopic.php?t=20849
http://www.ngwclub.com/forum/viewtopic.php?t=41432
http://www.ngwclub.com/gallery/main.php?g2_itemId=34223
- Cakey
Good on yah Roncar. Thanks for pointing in the right direction.
I like your trick with the tool. I am going to try that tonight as the second one is being quite stubborn to remove the thread top bit and I don't want to destroy my circlip pliers or the threaded cap.
Just out of curiousty how long has your neutral switch lasted since you cleaned and installed in the bike? Just wandering if this is a semi permanent type of fix as to me there does not seem to be to much that could go wrong with it once cleaned.
The second one that I am doing is already working but if it is a pretty permanent type of fix then I will dismantle and clean it regardless.
Look forward to your feedback on duration of fix.
1975 Gl1000
- roncar
To be totally honest, the neutral switches in my bikes work, so I have not used a rebuilt one yet. "Hal" has installed a rebuilt one and I haven't seen him post of a failure yet.Cakey wrote:...Just out of curiousty how long has your neutral switch lasted since you cleaned and installed in the bike?...Look forward to your feedback on duration of fix.
- Cakey
Cool thanks mate.
Someone might chip in if they have done the fix and installed.
1975 Gl1000
- 2 Replies
- 483 Views
Last post by BikeMaine
- 17 Replies
- 1356 Views
Last post by tlbranth
- 7 Replies
- 477 Views
Last post by CYBORG
- 6 Replies
- 837 Views
Last post by rcmatt007
- 6 Replies
- 189 Views
Last post by Dirty Dave
