I know there was a head bearing re-seat and adjustment write-up somewhere on the Internet in the past. It involved tightening the head down over-tight then working the bars back and forth before final adjustment. I had thought it was on the shop talk page here but it is not. After an hour of searching I cannot find it anywhere...
If someone could provide me with a link I would be very grateful. TIA
Head bearing re-seat procedure?
- drumgod
'81 GL1100
'77 GL1000
'76 CB550K
'77 GL1000
'76 CB550K
Re: Head bearing re-seat procedure?
i don't have a reference for the procedure , should be in the manual. but torquing it down then backing it off and re- tightening until the front wheel will just fall to the stop from the center position when allowed to fall on its own
There is some in the Shop manual but I do not think it references over torquing. It does say cycle like ten times and recheck IIRC. Puffy75 used to have it spelled out on his site but I can not find it anymore. http://www.retrorideinfo.com/tipslist.html
The jist of Puffys procedure was to tighten to the point where it would fall to the stop but not fast enough to bounce off the stop.
Pretty sure mike Nixon has a setup on his site also http://www.motorcycleproject.com/motorc ... cking.html
- drumgod
Thanks guys. That last link on motorcycleproject.com is exactly what I was looking for...
'81 GL1100
'77 GL1000
'76 CB550K
'77 GL1000
'76 CB550K
- Earl43P
So glad I read this! Mine has that classic symptom, wobbly during decel.
2008 GL1800 "yawn"
KTM390A “Hootinanny”
04 ST1300 DDDD (Double darksided daily driver) Sold 4/2022
93 GL1500I Double darksided and SOLD 3/29/20.
99 Valkyrie IS, Fast Black Double Darksided
"Fishtailed, flipped and flung me, but wearing it well". Sold!
82 GL1100 retired DD, needs work.... Sold 3/3/17
So glad that earl43p is glad, that it made me read it and even though I have read it before, I hadn't caught this "Though you probably found the locknut jammed against the tensioning nut, that's not the correct way to install it. It should be close to the tensioning nut, but not jammed against it. Leave a little space -- about 0.020". Then bend the locktabs into the locknut to keep the two interlocked. The locknut's job is to isolate the torque of the bridge nut from the steering bearings. Reassemble the rest of the fork per the manual. If a test ride reveals that there is still a decel wobble, or the bike sways side to side like a rowboat (the bearings are too tight), readjust to higher or lower spec as needed. Ride safely." Too much speed reading.
