In the process of changing out the timing belts on a 77 that sat in the weather for 10+ years (got it running now, btw!) after removing the belt covers, the front of the engine case and the "cylinder head covers" according to Honda are really oxidized. Also, the plates behind the tensioners, #s 3 & 4 on http://www.westernhonda.com/fiche_secti ... veh=131059 are really rusty.
I pulled the covers off an 80 1100, that has a frozen motor, to check the condition of those plates. It had none. I figured PO or his mechanic didn't reinstall them after a tensioner change. Checking the schematic for the 1100, it doesn't use them. All the other part #s are the same, so my question is are these even needed on the 1000 and if so, why?
As far as the oxidization on the rest of the aluminum, I'm just planning on pulling the cam pulleys and tensioners and using a wire wheel to clean it up some. Any thoughts on this?
Another Timing belt/Tensioner (sort of) question
- spiralout
Chris
1980 GL1100i w/ '77 donor engine
- Recycled Roadkill
Re: Another Timing belt/Tensioner (sort of) question
I didn't remember seeing those plated on my '78 when I recently did the timing belts on the '77, about 5 years apart. I also wondered if it would make any difference at all if they were installed or not but I always tend to figure if those that engineered such things they did it for a reason. However, I have no idea what their reasoning was or what purpose they have.
Bob Gill
'77 Honda GL 1000 Black Mamba (Sold)
Pretty sure those are just heat shields to protect the belts from the heat generated in the heads?? I do not see a reason beyond that why they would exist??
- Sandy
I just cleaned them up and painted them with engine paint.
Sandy
1971 Honda CB350
1974 Honda XL350
1975 Red GL1000 (gone from stable but still in the family)
1976 (original owner in 76) Sulpher Yellow GL1000
1977 Restored then Triked Sulpher Yellow GL1000
1976 (garage find completed 2015) Sulpher Yellow GL1000
1978 Watsonian Monaco
1960 IH B414
http://www.flickr.com/photos/76_gl1000_project
Sandy
1971 Honda CB350
1974 Honda XL350
1960 IH B414
- spiralout
All cleaned up and repainted. Planning on putting everything back in in the morning. I wire wheeled most of the corrosion off the aluminum, too. Ended up chucking a 12ga bronze bore brush in the drill for the hard to get to spots. It worked really well. As far as the heat shields, I wonder why the 1000s had them and the 1100s didn't. Over engineering on the earlier bikes or changes to the later that made them unnecessary?
Chris
- 4 Replies
- 637 Views
Last post by Goboy
- 11 Replies
- 1521 Views
Last post by canuckxxx
- 15 Replies
- 1521 Views
Last post by Sidecar Bob
- 9 Replies
- 277 Views
Last post by CYBORG
- 228 Views
Last post by Briang
