Is this head scrap?
- J4BPX
- My Album: http://www.aeromount.com/gallery
Is this head scrap?
Cleaning up a set of 79 heads just in case my the valve seats on my 75 heads are beyond salvage. The left hand cylinder head had quite a lot of calcium deposit under the gasket once I'd cleaned it off and a couple of the cooling channel holes were fairly blocked up. It was almost as if the PO had been using straight tap water in the heads. Where I cleaned off the calcium the heads are pitted and there is also some erosion around the edge of the valve depression. Is this acceptable or is this head scrap and / or could it be salvaged with a skim? Heads seem to be easily available in the US but not in the UK so I am just interested if it is worth saving.
- Head 1.jpg (49.25 KiB) Viewed 336 times
- Head 2.jpg (131.95 KiB) Viewed 336 times
A little inaccuracy sometimes saves tons of explanation - Saki
1976 UK GL1000 K1 'Trog' restored.
What's next?
The restoration at http://www.aeromount.com
What's next?
- MSGT-R
- Lady Winger
Re: Is this head scrap?
Pin hole corrision is never good. I may be clear through to the water jacket.
The gasket surface must be clean and flat or it won't seal.
You can try a clean-up pass, but if a couple of thousandths won't do it, I would suggest to go find another head.
81 Interstate: gone but never forgotten.
13 F6B
NGW Cartel
13 F6B
NGW Cartel
The ridge deterioration around the combustion chamber would be a concern. I would take a head gasket and lay it on there to evaluate how much impact that might have on the sealing surface of the gasket.
- backyardbob
- High Mileage Guru
I had a similar condition on my 77, machined .007 off the surface and it worked out ok.
i finally made it past the junkyard dogs!!
- MSGT-R
- Lady Winger
Use a thicker head gasket or a gasket shim if a lot comes off to keep the timing belts from having too much slack.
13 F6B
NGW Cartel
13 F6B
NGW Cartel
I wouldn't worry about that. The tensioners are there for that. But too much and you start getting in to valve to piston clearence issues.MSGT-R wrote:Use a thicker head gasket or a gasket shim if a lot comes off to keep the timing belts from having too much slack.
- MSGT-R
- Lady Winger
..and that's at least 10 thousandths or more.
13 F6B
NGW Cartel
13 F6B
NGW Cartel
- J4BPX
Sorry. I'm metric - is 10 thousandth equal to .254 mm?
What's next?
What's next?
Yup.
- MSGT-R
- Lady Winger
Oops.. sorry about that.
13 F6B
NGW Cartel
13 F6B
NGW Cartel
