Kevin, to whom I sold #2 82 has a problem and no internet access so I'm posing this question for him. At the time I sold him the bike I discovered PO had put screw in drip hole. When I removed it oil ran out. I gave him a new pump and George Fix gasket kit. He say he's replace it 4 times (even used new Honda O-rings and crush washers) and still has oil drip. I've searched on here but have not found a similar problem except as relates to crush washers. He also says old pump appeared in good condition (no slop). Any ideas appreciated.
Claude
ps. He is a mechanic.
Oil leak from water pump drip hole
Re: Oil leak from water pump drip hole
thats a tuff one. oil from the weep hole is normally a bad pump or crush washer. there is a picture showing the flow of both oil and water thru the water pump, that has been posted a couple of times. have you ck'd shop talk for water pump replacement
ck shop talk under water pump leaks. has an explanation by octane, with drawings, of how oil can leak
three ways oil can get there.... bad seal, pinched O-ring or crush washers.... unless of course the is a crack or something
i'm wondering about a crack as well. i think it would be hard to do it 4 times, and miss the mark every time
oh, give me a try.... I think I could
Thanks all, I printed out that stuff for him earlier and I was wondering about a crack also. I'll get the info to him and suggest he look for crack. I have spare parts if he needs them.
- 14 Replies
- 996 Views
Last post by Lowrider Bud
- 5 Replies
- 433 Views
Last post by Toehead
- 10 Replies
- 705 Views
Last post by Sidecar Bob
- 21 Replies
- 2442 Views
Last post by John Schmidt
- 20 Replies
- 1417 Views
Last post by 82aspy
