I put tubes and tires on the last 78.
The one I have now has some really old Metzlers. says tubeless on the sidewall. I am assuming there are no tubes.
Can I still go tubeless on my next set?
78 comstars -
- Pony Ruiz
78 comstars -
1978GL1000 naked - kinda sadly gone. no bike at the moment.
"The greatest shortcoming of the human race is our inability to understand the exponential function." Albert A. Bartlett.
- joedrum
Re: 78 comstars -
yes i always used tubeless on my 79 ...the only difference is in the opening of the valve stem hole there are stems made for this ...seems like yours has one already
1979 1000
- roncar
Re: 78 comstars -
I imagine tube only tires can be found, if you look hard enough, but most tires you buy will be rated and say tubeless on the sidewall. That is no firm indication that there isn't a tube in them.
Lots of people have reported success in running comstars (tube type on 78 and 79 Goldwings) tubeless. Your call but I can't in good conscious recommend it.
It has been suggested that they use tubes because tubeless tires on motorcycles were rare at the time and Honda ran them with tubes for liability reasons, not because they weren't capable of being tubeless. I have seen nothing to support this claim. If the rims aren't marked for tubeless.......
http://ngwclub.com/forum/viewtopic.php?p=257534#p257534
- IndianaJohn
Re: 78 comstars -
The difference is in the design of the bead areas of the rim. A rim designed for tubeless use is made to "capture" the bead of the tire. A tubeless rim does not have that. The idea is to hold the bead in place in case of a lower than normal air pressure situation. If you use a tubeless tire on a rim that is not designed this way, the tire can come off the rim or at least break the seal which could be catastrophic at speed. It really comes down to how important your safety is to you. Personally, I'd stick with the tube............
IJ
Stupid people shouldn't breed.
75 CB750
76 GL1000
82 Yamaha XV920J Virago
81 Yamaha XV750 Virago (parts)
75 CB750
76 GL1000
- Pony Ruiz
Re: 78 comstars -
thanks
i got/get it!
i got/get it!
Re: 78 comstars -
it is a "your call" thing.... I have had the rear on mine tubless for a long long time... but it is my butt on the bike, so you have to make your own choice
- 0 Replies
- 304 Views
Last post by oldwings
- 3 Replies
- 338 Views
Last post by Whiskerfish
- 6 Replies
- 518 Views
Last post by rcmatt007
- 9 Replies
- 921 Views
Last post by wingrider
