You can use ATF in a pinch but, MMO (Marvel Mystery Oil) is a better choice. Drain 1 qt. of oil, replace with MMO, go for an easy 100 mile ride, then drain and refill with oil. Good for cleaning many dirty things from your engine including your starters sprag clutch. I run it through mine at the end of every season.
That works great in the oil and a small shot in the gas.
1983 GL1100i//2013 Harley Softail Slim--(Both are red)
If it ain't red it ain't fast/If it is red and it ain't fast it must be broke!
