Hi Guys,
This is my first 77 wing, so don't laugh too hard ok. While removing the side covers, I discovered a kick starter leaver.
Question? Where does it attach to the bike? Do you need to replace the starter with a something to use it?
Thanks from Evergreen, Co.
Kick Starter
- Lead Member
Re: Kick Starter
on the rear of the engine there is a place that the lever fits into. it points outward. it will allow you to stand on the side of the engine and use your foot to push down, and start the engine. often if they are not used for a long while they will be stuck.
- wingless1
Re: Kick Starter
it plugs into a receptacle on the back of the engine near the generator/clutch area. There should be a rubber plug about where your left ankle would be when riding. Pull the plug, plug in the kicker, make sure you're in neutral, and kick. Have never used mine in earnest, but did try it out to see if it works, and it did (but mine didn't spring back up, have to pull it up to re-kick)--it's a great way to advance the engine when doing valve/ignition timing work.
guess cyborg beat me to it-oh well, shows how helpful and accomodating we all are:)
1975 GL1000, '13 beta 300rr, '? ct110, '82 kz440ltd, '84 vf750f, cm185t
gone and missed: xs650, cb650sc, ts400, drz400s
Re: Kick Starter
your explanation was better then mine wingless . but i haven't had my coffee yet this morning
- northwood
Re: Kick Starter
2015 Honda Grom (Soon)
2006 Honda VFR800 "Snowflake"
2007 Honda "Chicken Bacon Ranch" (CBR1000RR)
Previous Bikes:
1975 Honda "ol' Bird Dog" GL 1000 (Gone but not forgotten)
1982 Kawasaki AR80 (The one I will regret selling)
1982 Honda CM450E Not so Project "Connie"
1987 Yamaha Virago XV535
2005 Triumph Daytona 650
Previous Bikes:
- lcallison
Re: Kick Starter
If your bike is in a good state of tune, it is useable. I spent about 2 weeks using mine when the starter was out of commission. It's kind of awkward to use though. When I first got my 76 running in 2005, I started it with the kick starter.
Larry
84 GL1200A
79 GL1000
84 GL1200A
79 GL1000
- brokentoe
Re: Kick Starter
No.mishamouse wrote:Do you need to replace the starter with a something to use it?
I used mine once yesterday because my starter was tired after all the stops I was making. Mine, and quite a few others from what I've heard, is reluctant ...sort of catches ...when you first push down on it. I just give it a sort of quick sharp punch down with my foot, or heel of my hand, to get it past that catching point. Then as I push down repeatedly I don't let it travel all the way to the top...to the sticking point...until the engine is running.
I've been told that when manufacturers began using an electric start the public was skeptical about not having a kick start, so having both an electric start and a kick starter was a concession to the customers.
Faith, Family and Friends
'75 GL1000 (Feb 2012 BOTM)
2014 Softail Deluxe
1966 Suzuki S 32-2 Olympian
First Fire on Youtube!
2014 Softail Deluxe
- Toehead
Re: Kick Starter
Mine works surprisingly well! It always gets some looks when I use a kickstarter on a 1000 CC bike.
1975 TS125 (Sold), old smoker
1980 CB750C (sold)
1980 CB750C (sold)
- bladredhead
Re: Kick Starter
kickstarter is also super handy for setting timing, and valves and clearing liquid gas out of your cylinders when you forget to shut the petcock off and a float valve decides that 35 years is long enough to complete a career. be sure to remove the spark plugs first if you get a similarly lazy float valve
- 8 Replies
- 478 Views
Last post by NCScooter
