How your cooling system works and such
I recently have been exploring the possibility of using a high pressure radiator cap, such as those offered here: http://www.mishimoto.com/mishimoto-high ... 3-bar.html
Doing my research I found this article on cooling and thought it worth sharing. Enjoy!
http://www.tuneruniversity.com/blog/201 ... iator-cap/
- vonzoog
- Lead Member
Re: How your cooling system works and such
Thanks, a lot of that information I knew/ thought to be true. I did learn something about running straight water and water wetter. I may be adding some wetter to the antifreeze in the future.
Hi All - used to drive a shovel nosed pontiac transam with no airflow thru the radiator. when water wetter came out I used it for a run from CA to TX in mid summer and dropped 20+ degrees, so unless it's freezing time I like it!...kenai
2 - 1979 GL1000
1 - 1978
1 - 1977
1 for parts
1 - 1978
1 - 1977
1 for parts
- ole496
I never even considered finding an upgrade to the cooling system and I had no clue that a high pressure cap could do so much to increase the ability to cool the engine. That was a very useful article Sunnbob -- thanks!
1976 GL1000 "Double Nature" https://youtu.be/IK0YS2uuZtc
Our greatest weakness lies in giving up. The most certain way to succeed is always to try just one more time. -Thomas Edison
If you decide to run straight water and you live anywhere where the winter temperatures come anywhere near freezing, make sure you change to an anti-freeze mixture and run it enough that you are absolutely sure that any plain water in there has been mixed in thoroughly before winter storage.
A guy I used to know did a lot of work on his Trans Am's engine - hot carbs and all that stuff - and decided to run straight water in the summer and drain it for the winter. The next spring when he filed the cooling system it took a lot more water than he thought it should need. When he checked the oil he found out why. When he took the engine apart he discovered that a small amount of water in a couple of "galleries" did not drain and when they froze the block cracked.
- RIP: cookie
I ran an 18# cap for years by accident.
I had replaced an old one on the road one time and my old eyes missread the 18 for 13.
Last season when Steve (WF) and Dean (SB) were rescuing me from a failed stator 2000 miles from home we noticed the 'mistake'.
I replaced it with the 'proper' 13# cap .... now it runs hotter, still OK, but hotter.
I may look around for that 18# cap again.
- sgwilly
Dang. Wish you wrote this last year when I did this to my bike for 12 hours a day crossing the country during 100+ degree days. Now I know better. Thanks!
Steve
'09 Yamaha FJR1300AE
'99 Valkyrie Tourer
'89 Isuzu Trooper 3.4L
'83 GL1100 MonkeyWing (on IR)
'75 GL1000 (in the queue)
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
- vonzoog
- Lead Member
Dang? Did you say Dang? Dang is taking a nice steady picture at 80 MPH.
Dang!
Dang!
- sgwilly
Yeah. I did that with my phone and I kept thinking if the wind catches this thing it is GONE!!!!! That would have been a catastrophe 1000 miles from home and all alone. Kinda like being jettisoned back to 1983. We have it so easy nowadays.
Steve
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
'99 Valkyrie Tourer
'64 MGB
IBA #58082
SGWilly Gallery
Maybe you should just look for another 13 lb cap. It worked for you once, and I don't think your eyes have gotten any youger!RAT wrote:I ran an 18# cap for years by accident.
- RIP: cookie
Careful ....
Gord (pots and kettles) Jones
- Marc
This is real good information, however; remember what they stated in the article, "So if some extra pressure is good, why not a lot? Well, it may seem obvious, but the cooling system on your car is rated to a certain pressure. The radiator cap is designed to be the weak point in your cooling system so it can safely vent pressure, you don’t want to use a cap that is so resistant to venting pressure that it causes some other part of the system to become the weak point."
On old systems, like many of our Goldwings, the extra 5 lbs. pressure can cause leaks that you didn't have before. You have to weigh the chance of overheating against the chance of springing a leak on your nice long road trip this summer. In extreme weather conditions on a newer bike, or a fresh well done rebuild and a radiator that has been tested above 18 lbs, I think this is a great idea.
Excellent point regarding antifreeze - more is not better.
Shalom, Marc
1975 GL1000 "Dresser"
1976 GL1000 Project Bike
1979 GL1000 Naked
2007 Triumph Bonneville
1970 Norton Commando
1979 GL1000 Naked
+1 on that.
I think it might be better to upgrade the fan or add an oil cooler or both. More work but less of a chance of causing more problems than you solve.
- 6 Replies
- 468 Views
Last post by ofb
- 11 Replies
- 620 Views
Last post by pjlogue
- 72 Replies
- 3252 Views
Last post by 5speed
- 10 Replies
- 456 Views
Last post by NotSoLilCrippseys
- 246 Views
Last post by rcmatt007
