lower engine mounting bolt removal
Re: lower engine mounting bolt removal
#31
If you have 1/4 inch of thread, put a nut on it, and tighten it with an impact driver. That should help pull it out, and loosen it up
Lads
#32
Post by Lads »
After PB Blaster, heat and a heavy hammer it is free. I think the spacer is a great idea if you have enough thread to work with. I knew this bolt was a lost cause so I used the brute force method. Had to cut the bolt end off once I stated to get it moving because it had mushroomed on the end.
Thanks for all the helpful advise.
gregforesi
#33
Post by gregforesi »
Wow, that was a tough one.
Was it corroded or just a bunch of road trash holding it in?
2006 GL1800 (Brutus Maximus)
Lads
#34
Post by Lads »
Corroded. Once I get the time to get a build thread started you can see what it looked like.
#35
I wonder if someone used a non-coated rod, although even a galvanized piece can rust. and Arkansas certainly has a humid climate
rnelson
#36
Post by rnelson »
I didn't really have a hard time getting that long bolt out, but there was a ton of rust in there when It came out. Later when I reinstalled the bolt it push out a bunch more rust that formed a small pile on the floor. Then I got my compressor to blow out the hole and created a rust cloud in my garage. The bolt wasn't even that rusty, so it's kind of weird. Anyway, I smeared grease all over it when I reinstalled it. Hopefully that will slow the rust down from coming back.
Rick Nelson
Charlotte, NC
99 Vulcan Classic 1500
08 Concours 1400
79 Goldwing GL1000 (No longer a project. She's a runner!)
#37
Anti seize on the nuts is a great idea as well as that bolt is right down in the wheel splash zone.
#38
anti-seize on nuts is always a good idea!
Lads
#39
Post by Lads »
Here is the bolt, one end broke off from my original efforts, other end cut since it had mushroomed from the beating.
Norbert R
#40
Post by Norbert R »
:smash :bravo
Nulla futuit datum...
1977 GL1000 - BOTM April 2015
Cafe Maximus Build Thread
#41
Looks like they at least used a real bolt. ;)
#42
there is a name for the iron droppings of deep sea wrecks... fericycles or something
rod willis
#43
Post by rod willis »
If you need a stock bolt I have a good one let me know if you are interested
Rod
rod willis
1976 GL1000
Lads
#44
Post by Lads »
Thanks rod. I think sunnbob is sending me one. I will let you know if I need it.
Started a build thread here: http://www.ngwclub.com/forum/viewtopic.php?
Currently called MotoNudo
http://www.ngwclub.com/forum/viewtopic.php?f=16&t=55367
#45
not sure why that did not form a link.... tried to edit your post but it still did not "link"
