1980 GL1100 engine removal / timing belts
Re: 1980 GL1100 engine removal / timing belts
Somewhere there's a post that tells what year the engine is based on the code.
Track T 2411 wrote:Somewhere there's a post that tells what year the engine is based on the code.
From Randakk's Cycle Shakk;
http://www.randakksblog.com/gl1000-vin- ... #more-1520
Cliff ;) )
deathbypizza
Post by deathbypizza »
cant get the circlip removed from the ujoint
1980 GL1100I (parts)
1978 GL1000
"I Have No Idea What I Am Doing."
chewy999
Post by chewy999 »
deathbypizza wrote:cant get the circlip removed from the ujoint
It can be a bit fiddly, and you need a decent set of circlip pliers like the ones I bought - http://www.tooled-up.com/product/draper ... 0wods9wH6g
As you can see, some of the attachments are angled to gain access, and it just takes a little practice.
anim-cheers1 anim-cheers1 anim-cheers1
Previous Rides,
1980 CB250N Good to learn on
1986 CBX550 Good commuter
Current bikes
deathbypizza
#20
will soemthing liek this work too?
http://www.princessauto.com/en/detail/s ... -p2921385e
1978 GL1000
chewy999
#21
Post by chewy999 »
Should do, there are loads of different brands out there. I would suggest you fit a new ring when the engine goes back in as well.
Previous Rides,
Current bikes
deathbypizza
#22
chewy999 wrote:Should do, there are loads of different brands out there. I would suggest you fit a new ring when the engine goes back in as well.
yea for sure
cant get the lower bolt out on the left i assume becvasue of the weight, once i raise the jack a little that bolt should pop right out eh?
17mm i think, sorta stripped ....
1978 GL1000
chewy999
#23
Post by chewy999 »
Not sure about 'popping' right out, but taking the weight will help. Be surprised if it's stripped, probably hasn't been out for years if ever.
Previous Rides,
Current bikes
#24
I looked at the listing for the princessauto kit. In its assortment of replacement tips, I didn't see any mention of 90 degrees tips.
You would best served with an external snap ring plier that has fixed 90 degree tips.
That type of plier would typically have a more compact head to better sneak into the u-joint confined space to remove the snap ring.
Here's just an example of the fixed tip style I'm referring to. You don't need a reversible set like these. Get an External snap ring set for better accessibility and visibility in the u-joint area.
http://www.globalindustrial.com/p/tools ... DQod-hoJ2A
Cliff ;) )
deathbypizza
#25
Found the ones I needdd today amoung a few other things. Got home and realize I didn't pay for or get the pliers after. Got to go back tomorrow hahaha
1978 GL1000
